Volks AutosBadger5
Results 1 to 7 of 7
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Not exactly vcds - wifi dongle
    I have a vcds I use whilst in the garage but have also now bought one of these eBay wifi dongles to connect my iPhone to the obd so able to do fault code reads etc if away from home.
    Has anyone else here used one?
    I am having problems with mine.
    It shows as connected in the iPhone settings/wifi screen but does not show any signal bars in the top menu.
    When I try to use any apps they do not see it as connected.
    Can anyone here help me to get the damn thing to work?
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    I have one of these I got the wifi elm 327.
    Have you changed the settings in your iPhone so it has an ip address 192.168.0.11 subnet 255.255.255.0 and router 192.168.0.10 then when you open up your app you might need to change the settings to manual and put in the ip address 192.168.0.10 and port 35000
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Thanks I will try that. I have tried changing the ip bit not the router address.
    What apps do you use with it?
    2001 S3 (AMK)
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Dashcommand works ok but the gauges can be a bit laggy at times I couldn't get rev to work with the gauges but it will read eml codes and FUZZYcar is I think very basic and I don't use it.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    So would you recommend dashcommand? Just quite pricey so would like a recommendation off of any one who have used them. Before I commit to buying it.
    Thanks.
    2001 S3 (AMK)
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    See pm
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    Thanks mate. Got it working with the settings you said.
    2001 S3 (AMK)
  1. Audi DRLs now not working - VCDS coding error
    By vagcat in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th July 2011, 20:48
  2. Replies: 5
    Last Post: 28th February 2011, 19:16
  3. Major VCDS Help, I changed the coding i should not have!
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2011, 17:31
  4. VCDS-Lite not working :(.......
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2010, 22:38
  5. VCDS reading not matching up with DIS reading!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2009, 22:05
