VCDS log, faults after mapping??
max69vk
Kingston upon Thames
Decided to scan the car tonight just to see what (if any differences) I could see after remapping with a Shark STS unit, I scanned the car & its come up with the faults below. Now I have no idea what these faults actually mean, is it pure co-incidence that these errors could have come up after mapping the ECU?
Monday,29,October,2012,17:48:17:50725
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72
VIN: WAUZZZ8P18A105183 Mileage: 97960km/60869miles
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Not registered 0011
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
Component: R4 2.0l PPD1.2 4350
Revision: --H52--- Serial number: AUX7Z0GNFN8003
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 74ECA76E177D0AB835D
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73EEA47212730D802C7
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0420
Revision: 213991 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
VCID: 71E2AE7A686F3F90DEB
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007875894
Coding: 01880F21B01410004F0000001900000000085E135C010002000000000000
Shop #: WSC 06314 123 08192
VCID: 458A2AAA0C67C330523
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 97770 km
Time Indication: 0
Date: 2012.10.12
Time: 19:50:00
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP001MFC4
Coding: 0071612
VCID: 4B9E1C922A033540847
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 41823EBA184FEF106EB
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 224NG001102327
Coding: 0004428
Shop #: WSC 00088 210 88691
VCID: 40843BBE1345E618615
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B0704DE
Coding: E9807F061002021103
Shop #: WSC 00370 210 91464
VCID: 30646B7EA3E57698915
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 211
Mileage: 97216 km
Time Indication: 0
Date: 2012.09.11
Time: 11:31:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 65
Mileage: 97770 km
Time Indication: 0
Date: 2012.10.12
Time: 19:50:10
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0GNFN8003
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0200
Revision: 0000012S Serial number: AUZBZ7LD209304
Coding: 0205755
Shop #: WSC 00141 211 17933
VCID: 346C676E57FD4AB8F5D
2 Faults Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 211
Mileage: 97216 km
Time Indication: 0
Date: 2012.09.11
Time: 11:31:32
Freeze Frame:
Mileage: 97210 km
Count: 1109
Clock: 11:31
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 211
Mileage: 97216 km
Time Indication: 0
Date: 2012.09.11
Time: 11:31:26
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0040
Coding: 0000688
Shop #: WSC 00294 210 62977
VCID: 428031B61D49F408771
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 00493 128 61104
VCID: 36685D66418158A8CB9
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980202002586D0985054C9FC637
Shop #: WSC 06314 123 12345
VCID: 438E34B20253FD007C7
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674752858380
VCID: 356A5A6A5C8753B0C23
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H03 0050
Coding: 0000688
VCID: 448C37AE075DFA3845D
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205755
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 211
Mileage: 97216 km
Time Indication: 0
Date: 2012.09.11
Time: 11:31:32
Freeze Frame:
Mileage: 97210 km
Count: 1109
Clock: 11:31
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 211
Mileage: 97216 km
Time Indication: 0
Date: 2012.09.11
Time: 11:31:26
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
00883 - Ross-Tech Wiki
this is for the 2nd fault
1st fault will clear
3rd fault 01044 - Ross-Tech Wiki
4th and 5th are your ariel
clear them and rescan after a drive
Thanks for that Bez. I'm sure the 4th & 5th are due to me fitting an RNSE unit without using the updated antenna (although it didn't come up before), strangly I didn't have a single fault before the remap & clearing the faults doesn't appear to do anything as they just come straight back again :(
So I've managed to get most of these issues sorted, some of them so stupid too like forgetting to put the DVD in the drive to register & forgetting I'd removed the BT unit to fit a newer one!
Im still getting these two though:
both of which have only appeared since the remap :(
call the company that did the remap and ask them if they have any idea as to why your geting them
as the code does say
Engine Control Module recently flashed or re-mapped
[h=2]01314 - Engine Control Module[/h][h=3]01314 - Engine Control Module: No Communications[/h][h=4]Possible Causes[/h]
  • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
  • Fault(s) stored in Engine Control Module
  • Engine Control Module recently flashed or re-mapped
[h=4]Possible Solutions[/h]
  • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
  • Check Measuring Value Blocks (MVB)
    • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
[h=3]01314 - Engine Control Module: Check DTC Memory[/h][h=4]Possible Causes[/h]
  • Check Engine Control Module for Fault Codes
[h=4]Special Notes[/h]
  • Engine Control Module stored a Code which influences other Control Modules Functionality.
  • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
[h=5]Categories[/h]
[h=5]Meta[/h]
http://automechanika.messefrankfurt.com/frankfurt/en/besucher/willkommen.html
Never seen this before and I scan all cars before and after remapping them. If it was done via the STS I would clear all faults then stick your stock map back on and do another scan to see if anything is flagged up. If not load the performance map back on and do the same.
Hi i'm getting exactly the same fault and my car was remapped about a month ago
have you found out any info on this? i contacted the guy that mapped it and he's looking into it but he says he hasn't seen this fault before, as the ross tech site says it does seem to be to do with the map?
Hello,
this is quite normal and nothing to worry about, providing the faults clear. What happens is during the flashing process the ECU enters programming mode and cannot communicate wit the CAN gateway or other CAN modules. DTC is therefore stored. Once ECU is mapped faults should be cleared and not return.
Rick
Hello Rick,
i have cleared the faults twice and they still come back? what could this mean should i take it back to the guy that mapped it?
Tim
I would take it back and ask him to clear the fault codes. If he cannot do so, then something in the flash screwed communications. He needs to fix that.
