Chris NottEM Tuning
Results 1 to 8 of 8
    chris1988brown's Avatar
    middlesbrough
    578
    No Long Coding Helper Option
    I've recently bought my friends Vagcom cable. Having installed the software I am unable to get to some options that I want to (Gauge Sweep, Coming home lights, etc etc)
    The problem I am having is that all the guides tell me to go to 17-Instruments -> 07-Coding -> Long Coding Helper. The problem is in the coding section there is no option to select the long coding helper. I can access the long coding helper from the CAN Gateway module which is what is confusing me. Why is the long coding helper available in the CAN Gateway module but no others?
    chris
    Edit: Car is a 8P A3 2007 2.0 TDi S Line and the software is VAGCOM 11.11.3
    MY S-LINE 2.0TDI HYBRID PROGRESS
    MY PROGRESS THREAD
    Jun 2011
    Great Melton Norfolk
    1,340
    Have you used the long coding helper in the CAN gateway module?
    Is the software/cable original?
    middlesbrough
    578
    hi, yes ive used it in the CAN gateway module
    yes i believe they both are
    MY PROGRESS THREAD
    Sep 2007
    North-East UK
    93
    Chris,
    As far as I know the Instruments don't use long coding for the 8P. As you have seen the CAN gateway along with the Central Electronics and Central Convenience are the only modules that use long coding.
    Where did you pick up the coding instructions from, and are you sure they are for the 8P? The VCDS details are here:
    Audi A3 (8P) Instrument Cluster - Ross-Tech Wiki
    Steve
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    Jul 2012
    Does that mean you cant enable the gauge sweep on the 8P?
    middlesbrough
    578
    Quote Originally Posted by JST_A3 View Post
    Chris,
    Steve
    hi Steve i got the coding instructions from Google however now i come to think of it i don't recall it stating it was for the 8p, as chewy Norman says, does this mean it cant be done on the 8P?
    chris
    MY PROGRESS THREAD
    Sep 2007
    North-East UK
    93
    Chris,
    The gauge sweep is standard for the S3, but I think this is hard coded into the instrument cluster rather than it being a setting change, so you could do this but would need to replace the clocks.
    Coming home on the other hand is possible, details here:
    VW Golf/Jetta/Bora (1K/5M) Tweaks - Ross-Tech Wiki
    Steve
    MY2011 A1 TDI Sport
    26,720
    Post a log of your car.
  1. Need Long Coding for 2009 Facelift Sportback Tail Lites
    By NY_Sportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st March 2010, 14:50
  2. long coding
    By Aspen in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th April 2009, 21:27
  3. Long Coding Bytes missing
    By phil_w in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th February 2009, 07:57
  4. CAN gateway long coding 9 byte help
    By GeoffT in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th December 2007, 06:18
  5. PR CODES (da vinci code your Optional Equipment!)
    By pea. in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2007, 11:27
