    May 2012
    RETFORD, NOTTS
    1,707
    Fuel tank calibration?
    I saw some menus on vcds relating to the fuel tank.
    Since fitting a full dis and MTE, the MTE has always been too high, and goes down too slow.
    The fuel needle has always gone 120-150 miles before moving off the full mark.
    Can i recalibrate with vcds?
    Also looking at dash cluster codings, the cluster was from a quatro tdi, should i be coding it to 2wd, i read somewhere the quatro has 2 tanks, or a larger tank, could this be the problem? Where should i start looking?
    Thanks tom.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Apr 2012
    202
    If your car isn't a Quattro I would recode it as Quattro tanks are different shape and size to accommodate the propshaft. I would try this first before recalibrating the level sensor.
    Calibrating the level sensor requires draining the tank dry then only putting in what is seen as reserve quantity (see handbook about 8 litres I think) then you set the gauge up by hitting a button as the reserve lamp comes on. Not sure if that is how VCDS works but that's how the VW diag system works when I did one at work the other week.
    May 2012
    RETFORD, NOTTS
    1,707
    So my next noob question, how to recode as a non quatro?! :D
    It LOOKs straightforward, but i pooped myself after doing brake testing thingy with vcds yesterday, and then realised i had to go on a drive to get the abs working again! so i figure it will be very easy to break something!
    May 2012
    RETFORD, NOTTS
    1,707
    Recoded it, read my old logs before the dash change and was just one easy digit needed changing.
    Ian, thats interesting, wonder if i should go to the dealer and ask them to do this when the roof is painted next month.
    Dec 2006
    barnsley
    926
    do you mind tellng us exactly what you did in vag com
    i have exactly the same issue with the same car
    cheers
    nath
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    May 2012
    RETFORD, NOTTS
    1,707
    Dualmono, I just recoded the clocks to suit the 2wd car, as they came from a quattro. Have you done the same? If so the coding helper in vcds tells you what code to use. My mpg has settled over time to a beleivable figure, and the MTW seems a little more accurate now.
  1. Fuel tank question....
    By Izzy1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th December 2009, 14:33
  2. Vacuum in fuel tank
    By russ g in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th December 2009, 22:21
  3. TDI fuel tanks verse Petrol fwd/awd
    By Tifun in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2009, 20:19
  4. Fuel tank/warning/guage oddness
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st August 2008, 15:54
  5. 2.5 TDI Quat won't start - electric pump in fuel tank help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 10:41
