JMB RetrofitsAH Fabrications
    Dec 2011
    22
    HELP! VCDS assistance needed Sussex/Surrey/Kent
    I obtained a new copy of the satnav maps for my rnse (i drive a 2004 A6 C5 Avant), firmware updated without an issue and now the drive will not read the disc (its a copy)! all the research says if i use vcds to open the firmware refresh again i can put my original Audi disc in and all will be fine again (albeit out of date), it does still read the Audi disc but says its not compatible with my firmware.
    I would rather give someone £20 to do a scan and change the code to enable the refresh, than give Audi X hundreds to tell me i need a whole new headunit or dvd drive at the least.
    I don't mind travelling a little so if your in Kent or Surrey its not a problem
    27,111
    I'm in sussex mate, I do travel about, whereabouts are you?
    Dec 2011
    22
    Im in Crawley
    Reesy's Avatar
    East Sussex
    3,604
    Quote Originally Posted by d3m0n View Post
    Im in Crawley
    I'm in Sussex as well, and work in Haywards Heath so not too far.
    Saying that, Nige is definitely a better option!
    27,111
    Lol, thanks Reesy, crawley isnt far, you can always drop down to brighton as A23 is a 15 minute run easily, I'll PM you mate
    Dec 2011
    22
    Quote Originally Posted by Reesy View Post
    Either way im hoping a scan (hoping it shows no errors) and change to the RNSE refresh setting will allow for the sat nav to start working again!
  1. Replies: 5
    Last Post: 28th February 2011, 19:16
  2. HELP!!! - Audi Receipt Needed
    By Rooney in forum General Chat
    Last Post: 5th July 2006, 22:02
  3. Can any one read German? A little help may be needed.
    By Soupie69uk in forum General Chat
    Last Post: 12th August 2005, 11:11
  4. MOVED: Guys help me...I need you to back me up...
    By DaveS3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th December 2003, 12:29
  5. Getting an A3 - assistance needed.
    By willyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th November 2003, 11:29
