EM TuningAH Fabrications
    Jun 2009
    60
    VCDS Error codes
    I have the following error code
    18265 - Load Signal: Error Message from ECU
    P1857 - 35-10 - - - Intermittent
    it appears in two modules
    ABS/ESP module and the Gearbox module
    are they the same component flagging error
    can't find much info on these codes
    any help appreciated
    the car is a A4 2.5TDI Quattro
    27,043
    Where's the full log?
    Have you checked in ecu for any errors?
    Jan 2011
    Aberdeenshire
    646
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    Jun 2009
    60
    is this any good
    Sunday, 30 September 2012, 13:14:44.
    Control Module Part Number: 8E0 927 156 L
    Component and/or Version: AG5 01V 2.5lTDI RdW 2121
    Software Coding: 00001
    Work Shop Code: WSC 63351
    VCID: 3701A8DF0643
    1 Fault Found:
    P1857 - 35-10 - - - Intermittent-
    Address 03: ABS Brakes Labels: 8E0-614-517.LBL
    Controller: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04357
    Shop #: WSC 00861
    VCID: 263F759BD1E9
    2 Faults Found:
    01119 - Shareware Version. To Decode all DTCs
    35-10 - Please Register/Activate - Intermittent
    27,043
    Delete the code from ecu module 01 & see if it comes back, what exactly is the car issue though?
    Jun 2009
    60
    thanks for the reply HNH
    well, the issue is my ESP light lights up occasionally -- usually after a gearbox judder (has done this for a year or two)
    and very recently the car acts like it has a slipping gearbox -- but the fluid is quite new, and I believe topped up to the correct level
    I am trying to locate the TCM to check the connectioms etc if you know where that might be?
  1. VCDS Error codes
    By RallyX in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th August 2012, 20:06
  2. Cat Sensor Error Codes from VCDS....
    By jb0o in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2010, 08:44
  3. S4 Error Codes?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2005, 19:47
  4. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
  5. Flashing error code- "1n 1"
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 12:27
