JMB RetrofitsSky Insurance
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Code help please - 09571
    Hi.
    I have a fault code on my 2008 A3 2.0 TDI 170.
    It is:
    09571 Turbo Boost Control Position Sensor Circuit Implausible Singal P2563 Intermittent.
    Is this just a case of buying a new Pressure Connector sensor, or could it be something else?
    My car has been Remapped. Could this have anything to do with the sensor picking up bad signals?
    Any help would be great.
    Chris
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    331
    Without doing more tests, one cannot know. The fact that it is intermittent leads me to suspect a bad connection - that is, the signal is correct at times and other times it is not. To be labled intermittent usually means that the failure was not present at the time of the scan but had been previously set.
    Are you noticing a problem with the car's operation? If not, clear the code and watch to see if it returns. If it does, begin looking at connections. Don't replace parts just because you get a fault code.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    344
    Quote Originally Posted by bearthebruce View Post
    Car seems to be running fine, no lumping, misfiring, smoke etc. Turbo seems to be kicking in fine.
    I had the fault code cleared last week and it came up again the very next day.
    I've recently had an EGT sensor & MAF sensor replaced as well.
    Jul 2011
    15
    Quote Originally Posted by Djwoody View Post
    How did you solved these? I got same error today.
    May 2013
    32
    I also have this fault up on mine. Did you two get anywhere with it. Cheers
  1. 2.8 Fault code help please
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th January 2009, 20:54
  2. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2008, 07:14
  3. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2008, 18:31
  4. engine code help please
    By oadamo in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2007, 18:28
  5. VAGCOM Codes help please!!!
    By Herby1 in forum TT/TT-S/TT-RS Forum
    Last Post: 5th September 2007, 22:37
