EM TuningSky Insurance
    Sep 2012
    VAG COM alarm problems
    Hi,
    Just run vagcom on the car and returned the following,
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
    01374 - Alarm triggered by Terminal 15
    01370 - Alarm triggered by Interior Monitoring
    01134 - Alarm Horn (H12)
    The battery is also flat, I've just come back from a week holiday so this could be a coincidence. however could there be a drain somewhere in the alarm circuit causing the battery to drain?
    Thanks for your help
    27,129
    Delete codes, allot of them throw up occasionally anyway, then rescan & see whats left & if battery as flat after a week & its not new battery, then its new battery time most likely.
  1. Having problem getting USB cable to work with VAG.com
    By Rev-head in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th August 2007, 17:53
  2. Vag com seemed to cure my problem
    By Beef in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th June 2007, 01:04
  3. alarm beep help? vag-com?
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2006, 05:12
  4. Aftermarket radio problem with VAG-COM?
    By Dean_T in forum In-Car Entertainment
    Last Post: 5th September 2004, 18:11
