Monster MotorsportEM Tuning
    Apr 2012
    93
    VCDS, KPH BACK TO MPH
    hi all, my m8 has a 2003 mk4 golf, while messing with a memoscan 5053 he some how changed the mph to kph, and can not change it back to mph, can I change it back with my vcds cable ?, if so how do I do it ? please help thanks in advanced.
    Jun 2011
    Great Melton Norfolk
    1,340
    If you have licensed cable it can change it.. Not sure about lite or copies.
    Apr 2012
    93
    Hi m8 thanks for reaply, yes it a proper Ross tech cable not lite or copy cable, how do I change it back to mph? Thanks,
    QUOTE=gen.heinz guderian;1674017]If you have licensed cable it can change it.. Not sure about lite or copies.[/QUOTE]
    26,720
    Go into instruments 17 & check the coding or adaptation channels.
    snapon's Avatar
    Jul 2012
    36
    as NHN said check the coding of instruments
    if you hover over the box where you enter the value you should get an explanation of what each part of the coding relates to
  1. Speedo Question mph to kph??
    By Sarah's A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th November 2010, 21:52
  2. Tacho backing plate, MPH to KPH
    By Bing_IRL in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th February 2009, 11:10
  3. MPH to KPH conversion
    By dstamat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th January 2009, 16:37
  4. Change dials from mph to kph
    By necroeire in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2005, 14:01
  5. Welcome Back
    By DavidT in forum General Chat
    Last Post: 6th January 2003, 11:20
