JMB RetrofitsChris Nott
Results 1 to 18 of 18
    Jun 2012
    13
    Looking to do my own remap??!!!
    Hi guys I always like to try these things myself as its the only way you learn ,
    So through a friend Id made when I did a mechanics course I managed to get a copy of vagcom, just waiting on a laptop now as I'm a mac man.
    The otherreason I want to learn how to use it is id like to add the lbc abs cruise control which I've seen folk do.
    but I was wondering about a couple of things , the first being which cable as this seems like a mine field and also re map files.
    Audi A4, A6 Remap File 1.9 TDI 130BHP to 165BHP Tuned File VW | eBay
    Like this one, is it a good map? I've seen ones that offer more power etc and also I'm looking at future mods inc exhausts front mount turbo etc so how easy will it be to use a re map with those?
    sorry for the silly questions, I've done a bit of hunting and it's all confusing If Im honest, so flame away if necessary
    Jun 2011
    Great Melton Norfolk
    1,356
    you will need a licensed cable and software to perform most of the bits you want.
    As for the remap ,get it done by a reputable company.
    matt1.8t's Avatar
    Sep 2012
    70
    Alot of maps you can buy is just rewritten software on a laptop which any muppet can do and fugg it up big time.
    Only ever use DYNO tested maps as these are done on the car via a rolling road etc. These are the maps I use and have never had one back with a fault that was caused by remapping
    Aug 2012
    54
    On the Golf mk4 forum, alot of people have tried the black smoke remaps..
    Have a read on there. (BLACKSMOKE remaps lowcost tuning for VW Audi Skoda & Seat TDI - Home)
    27,114
    VCDS/vagcom will not remap a car, dont mess with things you dont have tools for as maps can basically disable the car completely, be warned.
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    +1 I tried and failed see this: oops! broke my ecu!
    Luckley the lad who helped me through it, sent my ecu back to me with a safe map (203bhp according to logs).
    Don't get me wrong it can be done, but inexperience will most likeley goose your ecu and you might not have the luck I had.
    Its not vagcom (VCDS) that does the mapping either its another program, and you have to use a cable with an FDTI chip in it.
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    Jun 2012
    13
    Cjsuk can I ask who helped?
    After having a look at the black smoke site I think this is one I may steer clear of, more research is needed me thinks
    Thanks for all the help so far guys
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    It's essentially piracy too, a so called proffesional encouraging the use of dodgy equipment
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jun 2012
    13
    The chap did only give me a copy of vag com, from what I can tell he's given me the wrong thing anyway so I wont be doing owt with it, maybe fitting cruise control and full obc. Would you rather I download it off a torrent site along with some illegal maps etc etc or borrow a copy of a friend who is a mechanic???? It's software lent between friends that is all, no need to be prudent about it.
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Quote Originally Posted by geoffersmaher View Post
    Ill get in touch with him and ask mate
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    Quote Originally Posted by cjsuk View Post
    I have asked, awating reply, you may receive a pm
    Jun 2012
    13
    Thank you cjsuk
    warren_S5's Avatar
    Oct 2007
    7,166
    Be careful, any damage you inadvertently cause could end up costing more than a basic remap, the tools aren't cheap for starters, and unless you have expertise and a clear understanding as to what you are doing (and what effect altering the parameters will have on other inputs), there is a risk of causing further engine / component damage which may also outweigh the cost of a basic remap. Tread with caution!
    Jan 2012
    Stockport, Cheshire
    748
    You misunderstand me.
    The cable equipment to remap costs thousands of pounds. If you haven't got this, then the only way of doing it is to use a non genuine pirated cable.
    Thanks, Rick
    Jun 2012
    13
    Quote Originally Posted by warren_S3 View Post
    thanks warren, this is why i asked it sounds far too complex for me to actually do with the limited experience i have with this sort of thing. that and all the stuff i dont have and needs thank you for the advice think ill kjust spend the 200 odd on a re map
    27,114
    The chap did only give me a copy of vag com, from what I can tell he's given me the wrong thing anyway so I wont be doing owt with it, or borrow a copy of a friend who is a mechanic???? It's software lent between friends that is all, no need to be prudent about it.
    With respect, there's no such thing as a copy of vagcom in genuine terms, as the license is in the genuine cables & the software is free to download & use with such, so why he has given you a copy defies logic unless he has given you a counterfeit cable aswell, also there is no such thing as software lent between friends when comes to vagcom as again its the cable that does the authentication & its free to download.
    Also software lent between friends when comes to licensing from many software vendors, unless is used on the same pc goes against the license purchased.
    So on one hand its more than likely the mapping software/cable are counterfeited & other hand vcds aka vagcom is also possibly the same, both of which you would be stupid to even consider using on your car IMHO.
    Also, its not about being prudent, so I think thats an unfair comment, its about giving you sound protective advise using fake tools on your working car, if it goes tits up then you'll be back on here or another forum complaining & then asking how to fix it, common sense prevails, ok you want to learn, but learn sensibly, not at a huge cost of cocking it all up.
    This is posted as friendly, not to cause friction, so please dont take it as such Geoff
    Jun 2012
    13
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Thanks, Rick
    thanks for the info rick, i did not know this and nor did my mate at the garage either, they specialized in ford stuff mainly 60's and 70's but he had a copy kicking about
    this is why i joind the forum for its wealth of info from knowledgeable folks
    Jun 2012
    13
    Also, its not about being prudent, so I think that's an unfair comment, its about giving you sound protective advise using fake tools on your working car, if it goes tits up then you'll be back on here or another forum complaining & then asking how to fix it, common sense prevails, ok you want to learn, but learn sensibly, not at a huge cost of cocking it all up.
    This is posted as friendly, not to cause friction, so please don't take it as such Geoff
    i certainly dont take it in any bad way , and im here for all the help i can, like i say i try to take my hand to whatever i can including body work fitting coil overs all servicing etc etc so i always like to have a go.
    and again like i say my friend had a cd lying around his work shop so i thought id look into it.
    i didn't realize it would need cables with signatures etc etc as my only experience of obd is the Bluetooth adapter i have stuck int my obd port on the audi and the torque app i have on my android phone.
    like i say im hear to lean so i can only thank you guys for the help
  1. Something to look out for when choosing remap..
    By badger5 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2012, 14:46
  2. Star performances own Remap softwear.
    By Biggied in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2010, 00:47
  3. Doing your own remap!!!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2009, 13:17
  4. Looks like APR have sorted the 2.0TFSI OBDII remap....
    By Cupramax in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th June 2005, 11:26
