EM TuningAH Fabrications
    pns2007's Avatar
    Nov 2008
    627
    Audi A1 Door control module scans
    Hi, I've just retro-fitted heated and folding mirrors on my 2012 A1. (Mine didn't even have heated mirrors wtf).
    I did it by purchasing the entire new mirrors, looms and updated control modules from a German breaker.
    VCDs has allowed me to enable heated and folding options through accessing the control module and the mirrors are working fine.
    I'm not too sure how these systems work and whether there are un-mapped parts of the control modules which can't be accessed by vcds yet.
    If anyone has an A1 with heated and folding mirrors would they mind posting me a vcds scan of the two door control modules please, so I can compare the coding with mine.
    Also, as a general comment, does anyone know if certain outside temperatures have an effect on the switching on or off of the heating element in the mirror. e.g. Mine come on (and its 19 degrees outside) when the engine is started and the mirror switch is in the central position. VCD's tells me that they are set to stay on for 600 seconds (and this appears to be correct).
    What happens after the 600 seconds and the outside temperature is below freezing? Do they automatically come on again? Also, how hot does your mirror glass get, mine are quite hot, I can just about keep the back of my hand pressed against the glass!
    Are there any other vcd's changes which can be done regarding temperature etc with the mirrors?
    Neil
    2013 A5 2.0 TDI (177) Black Edition
    [s]2012 A1 1.4TFSI (185ps) Black Edition[s]
    [s]MY2010 A4 1.8T (160) S-Line executive in brilliant Red[/s]
    [s]2008 A3 TDI S-Line Cabriolet 8P3[/s]
    A4 (B8) Door warning light and Glovebox retrofits. A1 Heated Mirrors Retrofit
    Sep 2007
    North-East UK
    95
    Neil,
    This will hopefully be of use, it's not my car but an extract of a scan that I picked up from the A1 Forum to assist me in comparing coding of the various modules, this one has heated and folding mirrors:
    Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
    Part No SW: 8X0 959 793 E HW: 8X0 959 793 E
    Component: TSG FA H09 0410
    Revision: -------- Serial number: --------------
    Coding: 011E12201001000100
    Shop #: WSC 00046 000 00000
    VCID: 4FA7305B1EC60D1
    Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
    Part No SW: 8X0 959 792 E HW: 8X0 959 792 E
    Component: TSG BF H09 0410
    VCID: 4E992D5F19CC049
    This one is mine which unusually has heated but not folding mirrors, I've also enabled mirror dip on the passenger side:
    Part No SW: 8X0 959 793 C HW: 8X0 959 793 C
    Component: TSG FA H09 0409
    Coding: 011E02200C01120102
    Shop #: WSC 00046 123 12345
    VCID: 4D9AD29B14968C709A3
    Part No SW: 8X0 959 792 C HW: 8X0 959 792 C
    Component: TSG BF H09 0409
    VCID: 4C9CDF9FEF8C85788DD
    I hope this is of some help, let me know if you need any further details.
    Steve
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    pns2007's Avatar
    Nov 2008
    627
    Cheers Steve, I apreciate your help mate
    pns2007's Avatar
    Nov 2008
    627
    A question for Nigel (NHN) if you don't mind. In you experience of retro fitting heated and folding mirrors (bearing in mind mine didn't even have heated mirrors) are you able to give advice on whether its a simple case of checking the heated option through VCDs and folding option on VCDs, or are there other bytes to explore re temperatures settings. The A1 has had too much work done on it by Ross Tech yet. still being developed lol.
    Mine are getting quite hot!!
    Cheers Neil
    Apr 2011
    197
    just enable via each door controller and thats it
    no mmi/rmc function its a basic system input via switch output via door control
    all mvb's in door control units no other very very basic is the a1
    as temp increases the resistance decrease and the control unit has pre mapped values to work out on/off
    engine must be running from memory
    27,099
    Quote Originally Posted by a8 tech back View Post
    Jon, your back with a new username?
  1. Audi A4 B6 - Convenience Control Module - Coding Help Needed
    By amz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th May 2012, 21:44
  2. Audi A4\S4 LED Control Module
    By noname12 in forum For Sale/Wanted - Audi Parts
    Last Post: 28th September 2011, 13:13
  3. Control Module for Injection Pump (J399) - Audi A4, 2.5Tdi, Avant 2002, B6
    By seanr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2011, 20:24
  4. Audi S3 ABS Control Module knackered
    By LiverS3Mike in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2010, 10:35
  5. Where is the Door Warning Lightsd Control module!?
    By GSB1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th July 2006, 09:15
