Sky InsuranceAH Fabrications
    Aug 2011
    Question Bluetooth retrofit VCDS coding sanity check
    I'm going to be installing the OEM bluetooth to my B7 S4 at the weekend and have read loads of DIY guides so I think I'm just about there but wanted to double check my coding looks correct before I start the install.
    The car already has RNSE, MFSW, BOSE, CD Changer, Cruise, Aux in enabled and is an auto Avant
    Through the Wiki on Ross Tech site and various guides I have come up with the coding below:
    Steering Wheel = Coding 04142 (MFSW with voice & tel, Tip Paddles, Computer & Cruise installed, Rear Wiper as it's an Avant)
    No Adaptation changes required?
    Instruments = No Coding change required -
    Adaptation Ch 62 = 23 (16+Radio+Nav+Telephone)
    RNSE = Coding 0309757 (Audi A4 8E, not a Cab, Bose fitted, Base Plate diagnostic capable with Comfort Control, Aux in enabled, CD Changer and MFSW fitted)
    Phone = Coding 0011822 (Audi, RNSE High, New style wheel, Multi-Function Steering Wheel, Head Unit (e.g. RNS-E), Diagnostics via K-Line, English voice, English Display)
    Does that all look right? Just a bit hesitant as apart from enabling the aux and a few other little VCDS tweaks this will be my first major project
    Dec 2011
    Glasgow
    195
    Looks about right I used the guide on this page. The bluetooth module wiring/ coding is half way down the page
    http://www.f1computers.force9.co.uk/...s_Audi/RNS.pdf
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    Aug 2011
    I got the Bluetooth installed and coded last weekend. The install was pretty easy really - helped by having the wiring loom from NHN so it was just plug and play. Probably the worst bit was trying to untangle and remove the existing Parrot installation - a supposed professional install but a right mess and not a single proper connection - all just twisted wires
    Coding was easy with the VCDS and it all seems to work - The only thing I changed from my post was the steering wheel to 03142 but 04142 also seemed to work so not sure what the difference is, I just couldn't be bothered to change it again.
  1. TPMS - A3 2012 - Coding Issues? VCDS users please check!
    By Cruiser89 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4 Days Ago, 19:45
  2. VCDS help required in Bedford after RNS-E and Bluetooth retrofit
    By satj in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2012, 09:10
  3. Bluetooth Phone Kit Coding VCDS Talk2Can AMI
    By Magpie2121 in forum VCDS (formerly VAG-COM) forum
    Last Post: 30th June 2012, 20:44
  4. Bluetooth retrofit
    By jassa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st May 2007, 20:03
  5. A4 Bluetooth Retrofit installation pics
    By imported_craigyjp in forum In-Car Entertainment
    Last Post: 6th November 2005, 12:15
