hi all, can i check my abs is working with vcds? i dont want to bleed the brakes, just test the abs is working, ive all ready done a scan and no fault with abs, i changed the m/c last week and brakes are fine but not sure if the abs is cutting in as i nearly skided today when stoping quick, can i test/reset the abs with vcds without going all through bleeding them again? or jacking it up ? i just want to be sure the pumps working. thanks in advance
