EM TuningChris Nott
    Aug 2012
    high fuel consumption (act maf readings too high)
    Hi,
    Not sure if I'm in a right tread. Recenly I have purchased 06' audi A4 with 1.9 tdi engine (BRB). Before that i owned a 99 passat with 1.9 AJM engine. Both 115bhp, both PD. Everything seems to be perfect with audi, I'm driving same style, same route, but it uses more fuel! Diference is not big, but about 1liter / 100km more (about 8-10 im. mpg). Audi has DPF, has 205 width wheels instead of 195, but fuel consumption difference still is too big.
    Logged some data with vcds and compared two cars. One thing what is concerning me is that MAF readings of audi's is about 100-150 higher then specified. ( if more air is in, more fuel has to be added right?)
    Should i start searching for boost leak or may be something else is the problem ? EGR duty cycle is 99.6 when accelerator on the floor. No fault codes. Any other opinions why high fuel consumption?
    Thank you
    Jan 2011
    Aberdeenshire
    646
    Seems like it's a bit sluggish. too.
    I don't know the PD engine, but I believe they use the variable vane turbos
    It could be your turbo actuator rod length too long. I've had all sorts of grief on one of my 2.5 Tdi's that turned out to be the rod length too long. This increased fuel economy, decreased low down torque, and acceleration.
    Have a look at my thread 2.5TDi Sluggish which also links into a good 1.9 turbo logging thread.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
  1. PLEASE HELP!!!! High Fuel Consumption and Low Power
    By nlnasty in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2013, 15:03
  2. MAF readings too low?
    By goldy1234 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2013, 09:03
  3. Heater blowing cold and temperature gauge reading too high
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 15:06
  4. MAF signal too high. any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 21:23
  5. HIGH HIGH Fuel consumption but-
    By ang12el in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th October 2007, 11:33
