Monster MotorsportBadger5
    Flat Out
    Apr 2007
    Essex
    144
    VCDS Error codes
    Hi, I am normally found lurking around on the A3/8p forum, however I also own a 3.0 tdi Touareg. Listed below is the latest scan as EML has been on for a couple of weeks with no difference to the drive. Was wondering if someone could guide me in the right direction as to what is required to put right the problems. Although I have the VCDS cable I am not ofay with how to use it to its full potential. Help would be grateful as to what Open Circuit means on glow plug and what the Intake Manifold Runner Control actually is. Part no's would be an added bonus. Also in Central Conv- why have all those part no's come up if there is no fault? Cheers.
    Monday,27,August,2012,07:03:00:54364
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Iain Muir RallyX
    Chassis Type: 6N0
    Scan: 01 02 03 05 06 08 09 15 16 17 18 19 22 36 37 46 56 68 76
    VIN: WVGZZZ7LZ8D058130 Mileage: 91230km/56687miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    18-Aux. Heat -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    68-Wiper Electr. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 7L0 907 401 F HW: 7L0 907 401 D
    Component: 3.0L V6TDI G000AG 0040
    Revision: --H05--- Serial number: VWX3Z0H1709418
    Coding: 0011779
    Shop #: WSC 31414 790 00001
    VCID: 2E5879A2BAC31968839
    2 Faults Found:
    012597 - Intake Manifold Runner Control
    P3135 - 001 - Lower Stop not Reached
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 254
    Mileage: 89851 km
    Time Indication: 0
    Date: 2012.07.14
    Time: 20:59:35
    Freeze Frame:
    RPM: 756 /min
    Torque: 70.2 Nm
    Speed: 0.0 km/h
    Voltage: 13.91 V
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    Duty Cycle: 80.9 %
    005662 - Glowplug for Cylinder 5 (Q15)
    P161E - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 89851 km
    Time Indication: 0
    Date: 2012.07.15
    Time: 08:14:08
    Freeze Frame:
    RPM: 903 /min
    Torque: 105.3 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.53 V
    Duty Cycle: 24.5 %
    Temperature: 15.3°C
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No SW: 09D 927 750 FA HW: 09D 927 750 FA
    Component: AL 750 6A 0992
    Revision: 00H61000 Serial number:
    Coding: 0004456
    VCID: 72E0ADD26E7B7D88271
    No fault code found.
    Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
    Part No SW: 7L0 907 379 L HW: 7L0 907 379 L
    Component: ESP ALLRAD MK25E1 0303
    Revision: 00H53001
    Coding: 0004354
    VCID: 42803D12195B8D08771
    Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
    Part No SW: 3D0 909 139 B HW: 5WK 485 04
    Component: Kessy 6840
    Revision: 68406620 Serial number: VWX3Z0H1709418
    Coding: 0000232
    VCID: 28548FBA98274758495
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    Address 06: Seat Mem. Pass Labels: None
    Part No: 7L0 959 760
    Component: Sitzverstellung 0701
    Shop #: WSC 00000 000 00000
    VCID: F7F61CC6821998A090F
    Address 08: Auto HVAC Labels: 7L6-907-040.clb
    Part No: 7L6 907 040 AF
    Component: CLIMAtronic R/L 4331
    Coding: 0000530
    VCID: 74ECABCA136F73B835D
    Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
    Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
    Component: J519 2000
    Revision: -0004--- Serial number: --------------
    Coding: 600001002B001C000000000000000000
    VCID: 8004771AD7D7DF18A15
    Address 15: Airbags Labels: 7L0-959-655.lbl
    Part No SW: 7L0 959 655 HW: 7L0 959 655
    Component: J234__37 VW8T 0250
    Revision: 92012025 Serial number: 0039P0040N5Q
    Coding: 0013111
    VCID: FAF005F2B10B85C8EF1
    Address 16: Steering wheel Labels: 7L6-953-549.lbl
    Part No: 7L6 953 549 F
    Component: J527 3601
    Coding: 0010012
    Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
    Part No SW: 7L6 920 985 Q HW: 7L6 920 985 Q
    Component: J285 KOMBI-INST. 7520
    Revision: KHH06V02
    Coding: 0007401
    Shop #: WSC 00098 067 57207
    VCID: 4B9E10362A114C40847
    Address 18: Aux. Heat Labels: Redir Fail!
    Part No: 7L6 815 071 G
    Component: Standheizung E1MAC 0425
    Coding: 0000000
    VCID: 366851C2419321A8CB9
    Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
    Part No SW: 6N0 909 901 HW: 7L6 920 985 Q
    Component: J533 GW-K-CAN TP20 7520
    Coding: 57E2EF8D48056003
    VCID: F0E427DAE377CF98515
    Address 22: AWD Labels: None
    Part No: 0AD 927 755 BG
    Component: TRANSFERCASE 0126
    VCID: 8102721EDBDDD610AEB
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzverstellung 0703
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 7L6 035 680 A HW: 7L6 035 680 A
    Component: RNS-MID H04 1022
    Revision: AB001001 Serial number: VWZ6Z7H7030092
    Coding: 020004000400002200
    ASAM Dataset: ------------------------- ------
    VCID: 306467DA63F70F98915
    Address 46: Central Conv. Labels: 7L0-959-933.lbl
    Part No: 7L6 959 933 A
    Component: 1G HSG 0600
    Coding: 0000065
    Shop #: WSC 00098 210 83434
    VCID: 4084371A10579F18615
    Part No: 7L0 959 701 R
    Component: Tuersteuergeraet FS 6303
    Part No: 7L0 959 702 R
    Component: Tuersteuergeraet BF 6302
    Part No: 7L6 959 703
    Component: Tuersteuergeraet HL 0202
    Part No: 7L6 959 704
    Component: Tuersteuergeraet HR 0202
    Part No: 7L0 907 719 A
    Component: Neigungssensor 0020
    Part No: 7L6 951 171 B
    Component: Innenraumsensor 0020
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
    Part No: 7L6 955 119 C
    Component: J400__ Front Wiper 5301
    Coding: 0001397
    VCID: 3A7045F2758BC5C82F1
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 010208 046 0204
    Coding: 00208933
    Shop #: WSC 31414
    Address 76: Park Assist Labels: 3D0-919-283.lbl
    Part No: 7L0 919 283 F
    Component: 0D Einparkhilfe 1107
    VCID: 39725AFE748DCED026B
    Jul 2012
    Cheshire/N Staffs
    1,316
    Either your glow plug has developed an open circuit (opposite to short circuit) and is faulty, or the connector has fallen out, or there is a break in the harness leading to it. Most likely is a dropped off connector, next step test the glow plug with a multi meter for resistance. If Zero Ohms, then it's new glow plug time.
    Inlet Manifold runner - either the plastic rod has broken, or a flap inside the inlet manifold has broken, or it simply need recalibration - a dedicated Touareg forum will be able to help more. It's common for the plastic rods to go.
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    Flat Out
    Apr 2007
    Essex
    144
    Thanks veeeight for info. Also found some info on a4 b7 forum this morning from nov11 and this was very helpful. After following one of the tips I have sorted the problem with no cost. Took off motor from bank 2 to swap to bank 1 and when i got to bank one found that the arm had come adrift from the ball and socket. Connected this up and put back bank 2, rescanned and hey presto no EML. Problem with glow plug was trapped wire causing a loose connection to the plug. Happy bunny again.
    27,097
    This is a great thread, good factual info with a fix, good going
    Flat Out
    Apr 2007
    Essex
    144
    Repair was short lived. Turns out that the socket on the arm has worn and keeps popping off. Does anyone have Elsawin to furnish me with part no. please? My local stealers are about as good as most of them (pretty useless) so I would like to go armed with part no. to order a new one. Cheers
    27,097
    Its etka not elsa mate & tbh better getting part number from etka at dealer as part numbers given on forums can sometimes be wrong or the part number of the part itself which it should be stamped with.
  1. Cat Sensor Error Codes from VCDS....
    By jb0o in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2010, 08:44
  2. error code 00575, and sqealing noise
    By lowrider786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2005, 23:38
  3. S4 Error Codes?
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th April 2005, 19:47
  4. Error codes!
    By S4ZippyZoo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th November 2004, 12:43
  5. Flashing error code- "1n 1"
    By randallons in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th October 2004, 12:27
