EM TuningMonster Motorsport
Results 1 to 18 of 18
Thread: vagcom help
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    vagcom help
    having a problem with my vagcom lead i got on monday (not an ebay lead)
    this is the test page. is this what it should look like (non CAN car)
    i can't access any engine data i've got very little access to anything.
    i'm also trying to add the locking beep to the car. tried adding 1024 made no difference. i've added anti-hijacking which worked fine.
    this is the list i got on the C/L controller
    Audi A3 8L 1.8T breaking.
    front bumper, impact bar, slam panel, full engine and loom sold.
    everything else for sale.
    Jun 2011
    Great Melton Norfolk
    1,340
    Post this in the vcds section NHN (nigel)will help.
    26,716
    So how are you trying to access a module?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    want to get into 01-Engine. to view measure blocks.
    26,716
    I said how, now why :P
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    open VCDS (latest)
    select control module
    click 01-Engine
    then says no responce from controller. with the engine on and off
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    612
    Re: vagcom help
    What about if you scan for all faults. Will it read from the control module for the engine?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    this is all what it will access with a full auto scan
    Friday,17,August,2012,10:17:27:05128
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
    Part No: 1J0 907 379 H
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 13504
    Shop #: WSC 06435
    VCID: 3666866C125375A8CB9
    No fault code found.
    Address 15: Airbags Labels: 8L0-959-655-AI7.lbl
    Part No: 8L0 959 655 F
    Component: Airbag 7 Audi 0505
    Coding: 00104
    Shop #: WSC 06313
    VCID: 418CE5B04B9DC2106EB
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 14187
    Shop #: WSC 06313
    VCID: 428EEABC4E9BD908771
    3 Faults Found:
    01134 - Alarm Horn (H12)
    76-00 - Terminal 30 missing
    77-00 - Internal Supply Voltage
    49-10 - No Communications - Intermittent
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 06313
    VCID: E0CA803460572B18C15
    Address 56: Radio Labels: 8D0-035-1xx-56.lbl
    Part No: 4B0 035 186
    Component: Radio 0001
    Coding: 00207
    Shop #: WSC 06313
    VCID: DDB4B9C0572506F0EA3
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    612
    Re: vagcom help
    Its skipping it by the looks of it. The only other way to know if its fault with your car or computer would be to try another laptop/computer.
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    612
    Re: vagcom help
    Also try another car possibly mates or family member.
    26,716
    Urm it shows in the list to be scanned, does it actually try & connect to module 01 & then come out with no results?
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    will open.
    trys to connect
    comes up with no responce from controller. which is says for most of the others modules aswell.
    tried a 1997 A4 same thing.
    will try a 2000 seat ibiza today see if i can talk to that
    26,716
    Ok remove the software & drivers, then go into windows explorer & c drive & delete any vcds, ross-tech, ross-tech, vagcom folders that should be located in root of the drive, also check in program files, program data, program files (64) depending on OS installed some folders may not be present.
    Then restart machine, reinstall vcds from RT download site taking note of which drivers are installed if ur system is 32 or 64 bit, test again directly into the module 01 or select 8L from the autoscan drop down box.
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    326
    I've been reading the replies. You could have an issue in the car. The engine controller may not be talking on the diagnostic bus. After you try what Nigel has suggested, I suggest that you try another car and see if there is something dodgy about the interface. I'm not saying their is - but we need to rule it out. Once we know the install and wire are working properly, then we can begin to figure out what in the car is Fubar and keeping the Engine ECU from talking to the tool. You see, what I see in the list is a bunch of modules not talking .... Some may not be installed but still... looks like a KLine is hung. But we will go down that road once we know that the tool is all working properly.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    26,716
    Thanks for getting involved Bruce, appreciated as always
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    unistalled now
    which should download from RT
    HEX+CAN or HEX-USB
    on lead says:
    VCDS HEX-USB+CAN
    HC598967
    the engine will talk to my Autel hand held diagnostic
    26,716
    jay1601's Avatar
    Jun 2010
    kingsclere
    1,231
    installed again.
    tried to gain access to the engine on a 02 polo and a 05 passat neither would respond from the controller
    not sure whats not working. don't have any problem with the lead/laptop at work
  1. VAGCOM Help
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2008, 21:35
  2. 2008 S3 Vagcom help
    By Oli. in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2008, 17:07
  3. Haldex controll module leasking??? vagcom...help please
    By scott_johnson in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2008, 21:26
  4. vagcom help
    By quattrov6tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th November 2007, 20:50
