vagcom help
jay1601
kingsclere
having a problem with my vagcom lead i got on monday (not an ebay lead)
this is the test page. is this what it should look like (non CAN car)
i can't access any engine data i've got very little access to anything.
i'm also trying to add the locking beep to the car. tried adding 1024 made no difference. i've added anti-hijacking which worked fine.
this is the list i got on the C/L controller
So how are you trying to access a module?
open VCDS (latest)
select control module
click 01-Engine
then says no responce from controller. with the engine on and off
this is all what it will access with a full auto scan
Friday,17,August,2012,10:17:27:05128
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 H
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 06435
VCID: 3666866C125375A8CB9
No fault code found.
Address 15: Airbags Labels: 8L0-959-655-AI7.lbl
Part No: 8L0 959 655 F
Component: Airbag 7 Audi 0505
Coding: 00104
Shop #: WSC 06313
VCID: 418CE5B04B9DC2106EB
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D13
Coding: 14187
Shop #: WSC 06313
VCID: 428EEABC4E9BD908771
3 Faults Found:
01134 - Alarm Horn (H12)
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
49-10 - No Communications - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 06313
VCID: E0CA803460572B18C15
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186
Component: Radio 0001
Coding: 00207
Shop #: WSC 06313
VCID: DDB4B9C0572506F0EA3
Its skipping it by the looks of it. The only other way to know if its fault with your car or computer would be to try another laptop/computer.
Urm it shows in the list to be scanned, does it actually try & connect to module 01 & then come out with no results?
will open.
trys to connect
comes up with no responce from controller. which is says for most of the others modules aswell.
tried a 1997 A4 same thing.
will try a 2000 seat ibiza today see if i can talk to that
Ok remove the software & drivers, then go into windows explorer & c drive & delete any vcds, ross-tech, ross-tech, vagcom folders that should be located in root of the drive, also check in program files, program data, program files (64) depending on OS installed some folders may not be present.
Then restart machine, reinstall vcds from RT download site taking note of which drivers are installed if ur system is 32 or 64 bit, test again directly into the module 01 or select 8L from the autoscan drop down box.
I've been reading the replies. You could have an issue in the car. The engine controller may not be talking on the diagnostic bus. After you try what Nigel has suggested, I suggest that you try another car and see if there is something dodgy about the interface. I'm not saying their is - but we need to rule it out. Once we know the install and wire are working properly, then we can begin to figure out what in the car is Fubar and keeping the Engine ECU from talking to the tool. You see, what I see in the list is a bunch of modules not talking .... Some may not be installed but still... looks like a KLine is hung. But we will go down that road once we know that the tool is all working properly.
Thanks for getting involved Bruce, appreciated as always :)
unistalled now
which should download from RT
HEX+CAN or HEX-USB
on lead says:
VCDS HEX-USB+CAN
HC598967
the engine will talk to my Autel hand held diagnostic
installed again.
tried to gain access to the engine on a 02 polo and a 05 passat neither would respond from the controller
not sure whats not working. don't have any problem with the lead/laptop at work
7
2K
2K
744
