Chris NottVolks Autos
    Jul 2011
    Sheffield
    36
    Odometer from kilometers to miles
    Hi
    My odometer has switched back to kilometers, I have bought a ross tech cable to correct this amongst other things.
    I have figured out that in VCDS I would probably need to go to 17-Instruments then to CODING
    Now this is where I am a little stuck, I am assuming I need to change the country code back to 4 (was in another post back on here)
    But how do you actually do this?
    As I have software coding
    Workshop code
    Importer number
    Equipment number?
    Not too sure what I am doing here and don't want to screw it up
    Jul 2011
    Sheffield
    36
    Found this
    Vcds - How To Switch Display From Miles To Km? - VAGdrivers - sponsored by Alloy-Wheels.ie
    Code:
    {Instrument Cluster}
    Control Module Coding
    Select 17 (Instrument Cluster)
    Coding -> Function 07
    00??x0x: Extra-Options
    +01 - Brake Pad Warning active
    +02 - Seatbelt Warning active
    +04 - Washer Fluid Warning active
    +16 - Sedan (Jetta)
    00xx?0x: Country-Setting
    Note: Germany is coded as Europe, but 0 is a valid for germany.
    1 - Europe
    2 - USA
    3 - Canada
    4 - Great Britain
    5 - Japan
    6 - Arabian States
    7 - Australia
    27,038
    Use the DIS settings with wiper stalk mate, very easy to do
  1. RNS-E MK2 - Changing from KM to Miles
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th April 2011, 21:08
  2. Parking 1 million miles away from shops/cinemas/gyms etc
    By a3_dan in forum General Automotive Chat
    Last Post: 23rd March 2010, 17:59
  3. Changing from kilometers to miles
    By tp7n in forum VCDS (formerly VAG-COM) forum
    Last Post: 21st December 2009, 10:12
  4. Replies: 8
    Last Post: 19th April 2009, 16:05
  5. How many miles from a tank on a 1.8t Quattro?
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2007, 09:50
