Chris NottMonster Motorsport
Results 1 to 7 of 7
    pbi
    Aug 2012
    Urgent Help - Anyone with vagcom ready to help - NW London?
    Hello guys I was wondering if anyone would be kind enough to help me and have a quick look and do a VAGCOM scan to my car.
    I`m going away with the car this Friday and if someone can help with scan today or tomorrow will be perfect.
    Car is audi a6 3.0tdi quattro 2006, no mods/remaps done.
    There is no engine lights or what ever on the dash showing a problem. The car is bad on fuel and some times feels like is under power. I want to see what the scan will show up before I start changing MAF,MAP and etc. I believe that is possible this kind of sensors to be check with vag that they operate in the way they should?
    Anyone ready to help near NW London? I`m live in cricklewood ??
    I`m also working at Heathrow area at the moment. Thank you.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,434
    Quote Originally Posted by pbi View Post
    VCDS (formerly VAG-COM) forum
    look in the link above, click blue balloon for users in your area, there details pop up inthe left hand corner, pm them and ask them for a scan. Hope that helps you out. x
    pbi
    Aug 2012
    I send pm to some members. Than you Sandra.
    27,075
    Maf/s would be my 1st stop tbh, any smoke?
    pbi
    Aug 2012
    No smoke. I check all hoses for leaks - none. Car is running ok when cold or on aircon, but when get to normal temperature is a little bit sluggish and looks like under power and litle bit more noisy. I know that at cold start mixture is more rich and also when aircon is working and I pointing to the MAF, but if some one could help me with fast scan will be realy good.
    Today I change the fuel filter, new front brake disks and pads.
    Jul 2012
    192
    I have been experiencing similar problems and on here been told it could be my divertor valve
    worth a look imo
    snapon's Avatar
    Jul 2012
    36
    best thing instead of guessing do a proper scan it will save you money in the long run
  1. Anyone In The Northwest With Vagcom? Rns-e Help!
    By ian ditch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th May 2011, 23:03
  2. im sorry, but anyone with photoshop can u help me!
    By 06060918@Brookes.ac.uk in forum Photography & The Digital Darkroom
    Last Post: 30th July 2007, 23:23
  3. Anyone with VAG-COM to help setup Anti-Hijack door lock
    By bebecheekymonkey in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd February 2007, 22:04
  4. anyone with etka can you help?
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2006, 01:41
