Urgent Help - Anyone with vagcom ready to help - NW London?
pbi
NULL
Hello guys I was wondering if anyone would be kind enough to help me and have a quick look and do a VAGCOM scan to my car.
I`m going away with the car this Friday and if someone can help with scan today or tomorrow will be perfect.
Car is audi a6 3.0tdi quattro 2006, no mods/remaps done.
There is no engine lights or what ever on the dash showing a problem. The car is bad on fuel and some times feels like is under power. I want to see what the scan will show up before I start changing MAF,MAP and etc. I believe that is possible this kind of sensors to be check with vag that they operate in the way they should?
Anyone ready to help near NW London? I`m live in cricklewood ??
I`m also working at Heathrow area at the moment. Thank you.
VCDS (formerly VAG-COM) forum
look in the link above, click blue balloon for users in your area, there details pop up inthe left hand corner, pm them and ask them for a scan. Hope that helps you out. :) x
I send pm to some members. Than you Sandra.
Maf/s would be my 1st stop tbh, any smoke?
No smoke. I check all hoses for leaks - none. Car is running ok when cold or on aircon, but when get to normal temperature is a little bit sluggish and looks like under power and litle bit more noisy. I know that at cold start mixture is more rich and also when aircon is working and I pointing to the MAF, but if some one could help me with fast scan will be realy good.
Today I change the fuel filter, new front brake disks and pads.
I have been experiencing similar problems and on here been told it could be my divertor valve
worth a look imo
best thing instead of guessing do a proper scan it will save you money in the long run
