Sky InsuranceAH Fabrications
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    691
    RNS-E errors since retrofit
    Hello
    Earlier this year I had an RNS-E retro fitted to my 2002 Audi S3.
    Previously I had the single DIN cd player with storage tray.
    The system works as it should without any problems.
    I ran a check and the following faults appeared, which I tried to clear, but to no avail.
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
    Component: RNS-E HIGH EU H80 X---
    Revision: 20S Serial number: AUZBZ7K1101138
    Coding: 0505711
    Shop #: WSC 63606 123 87607
    VCID: 356A5A5C5F5A571
    7 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 83
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:56
    Freeze Frame:
    Mileage: 655350 km
    Count: 1507
    Clock: 11:00
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:53
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:10
    00625 - Vehicle Speed Signal
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:50:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:50
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    00466 - Control Module for Steering Column Electronics (J527)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    01299 - Diagnostic Interface for Data Bus (J533)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Freeze Frame:
    Bin. Bits: 10001
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0505711
    7 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 83
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:56
    Freeze Frame:
    Mileage: 655350 km
    Count: 1507
    Clock: 11:00
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:53
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:10
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:50:12
    Freeze Frame:
    Mileage: 655350 km
    Count: 1404
    Clock: 11:50
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Time Indication: 0
    Date: 2012.04.14
    Time: 11:10:43
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 62
    Freeze Frame:
    Bin. Bits: 10001
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Jay.Ing's Avatar
    Jun 2008
    North West
    273
    Did you sort this? Have you removed the RNS-E since you installed it?
    2012 A3 Ibis White SportBack Black Edition 140 - Going..
    Stuff for sale:
    Number plate LEDS
    Brand New Pipercross Panel Filter
    Light/Rain Sensor with Loom
    50mm H&R Suspension Kit
    Brand New H&R Springs (50MM)
    OEM Auto Dimming rearview Mirror
    Concert III with Aerial amps
    Red A4 Black Edition 150Tdi.... Arriving 29 July!!!
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    27,113
    He has an 8L you have an 8P so of no use to eachother tbh.
    Jan 2012
    1,837
    If you would search you would see that the ZF short to ground is a common error with retrofitted RNS-E due to ~>2007 cars not having the ZF aerial fitted.
    This can be fitted but most people don't bother but you will notice a small drop in FM signal because of the aerial the RNSE uses is not fitted.
    Both this and the Speaker connection errors can be ignored.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,520
    no probs i thought i did quote him
    im useing a phone well was when i posted and the swear filter usaly ******* the swear word
    i think thats needs looking at
    bez101's Avatar
    Jul 2008
    8,520
    oh yeah and i did meen to thank you for the part numbers etc i forgot
    so TY.
  1. Symphony II RNS-E sat nav Retrofit
    By benw123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th June 2012, 23:33
  2. Coding errors after Retrofit RNS-E, BT Phone and MFSW- Please help
    By dme in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th March 2012, 13:11
  3. Chorus RNS-E sat nav Retrofit
    By johnmv55 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2006, 21:47
  4. RNS-E and lighting retrofit guides
    By The911SC in forum In-Car Entertainment
    Last Post: 5th February 2006, 09:50
