AH FabricationsSky Insurance
Results 1 to 7 of 7
    Jul 2012
    Angry ESP light, Airbag light and yellow steering light
    Hello guys i am new to this forum please be gentle!
    I have a 2005 A3 TDI 2.0 BKD SLine quattro.
    I have just changed the dashboard and fitted RNSE and new (well remove from good donor car) steering angle sensor, steering ecu and cruse control stalk.
    I now have ESP light, Airbag light and yellow steering light on constant, steering is now very heavy.
    I have tried Ross techs calibration procedure with no joy and i have drove it apx 10 miles and its still the same.
    I have tried diagnose with vag com 409.1, lite and 311 all fail to get connection with controller and state "no responce from controller".
    I have both ross tech lead and usb lead and i cannot connect with eather.
    This is strange as i can diagnose and erase any engine faults.
    I am alittle stuck to say the least to how i can go forward with this so any help would be great.
    26,716
    Where did you get the cable from?
    cjsuk's Avatar
    Feb 2012
    Leeds
    554
    Disconnect battery for half hour, start car, stop car after a couple of mins then re try vagcom (just from experience).
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    326
    Your 2005 (8P) A3 does diagnostic by CAN. VCDS-Lite does not work with that car. Nor will 409 or 311. None of those support CAN diagnostics. You need a MicroCAN dongle style interface at the minimum and you must run full VCDS. Once you have those, post an autoscan here for us to assist you. Else, you will be spinning your heavy wheel.
    To the poster who says disconnect the battery - that will most likely not solve this problem. A diagnostic scan is needed to know the state of the modules in this car.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Jul 2012
    Thank you for your help guys,
    Bruse - your right as disconnecting the battery does nothing.
    The usb lead looks very cheap with it only having 4 pins present however same issie with expensive lead.
    I have spoken to a vag com specialist in my area who thinks the new parts will just need coding in.. He thinks the vag com that has been used by my friend is the problem so i should be ok with what he uses.
    Still confusing why i have been able to diagnose and delete engine faults but cannot access other areas of vag com.
    I guess if he does not simply fix the issue Sunday then he will mail me the fault codes so ill post them up to try problem solve.
    Again... MANY THANKS FOR YOUR HELP.
    Jul 2012
    Jul 2012
  1. New steering module, ESP and power steering lights on.
    By MxGaza33 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th June 2013, 01:16
  2. 2011 Rear lights for cash and your rear lights
    By roman3000 in forum For Sale/Wanted - Audi Parts
    Last Post: 1st December 2011, 17:39
  3. Help please... Yellow ABS light and ESP yellow on.
    By gkf9 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th October 2011, 19:52
  4. Battery died and now have power steering light and esp light on ?
    By bradus in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th December 2010, 14:46
  5. Heavy Steering and Battary warning light on ___ Help
    By rockfanatic in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st July 2007, 18:32
