EM TuningSky Insurance
    boost-addict's Avatar
    Aug 2011
    977
    what programme to read log files?
    as above. found open reader but only get numbers in boxes like a spread sheet, but doesn't show what each value is
    cheers
    26,776
    Excel or word/wordpad but depends on the log type, it denotes on column heads what the columns represent.
    Aug 2011
    977
    nope. , . in excel i dont get the title of each column
    it shows the titles in word. or if i rightclick and click edit on the file
    basicly ive noticed on iirc group 22 there's idle, part throttle, enrich,over run. as i put my foot down i get part throttle untill the boost builds and flicks to enrich. boost builds to 18psi but at 5k falls to 12psi and shows part throttle, is this correct?
    heres the logs
    LOG-01-011-003-002.csv download - 2shared
    LOG-01-022-003-013.xls.csv download - 2shared
    i get this
    Saturday,14,July,2012,17:14:19
    8D0 907 558 DA,,1.8L R4/5VT MOTR HS D01,
    ,Group A:,'022,,,,Group B:,'003,,,,Group C:,'013
    ,,RPM,Time,Time,Mass Flow,,Engine Speed,Supply Voltage,Coolant,Intake Air,,Timing Retardation,Timing Retardation,Timing Retardation,Timing Retardation
    ,TIME,,,,,TIME,,,Temperature,Temperature,TIME,Cyli nder 1,Cylinder 2,Cylinder 3,Cylinder 4
    Marker,STAMP, /min, ms, ms, g/s,STAMP, /min, V,°C,°C,STAMP,°,°,°,°
    ,0.37,840,1.50,1.60,4.17,0.75,840,13.650,61.5,31.5 ,0.00,0.0,0.0,0.0,0.0
    ,1.50,840,1.55,1.55,4.17,1.89,840,13.580,61.5,31.5 ,1.12,0.0,0.0,0.0,0.0
    ,2.62,840,1.50,1.50,4.23,2.99,840,13.580,61.5,31.5 ,2.26,0.0,0.0,0.0,0.0
    ,3.76,880,1.55,1.55,4.37,4.13,840,13.650,61.5,31.5 ,3.38,0.0,0.0,0.0,0.0
    ,4.88,840,1.50,1.50,4.17,5.25,840,13.650,61.5,31.5 ,4.51,0.0,0.0,0.0,0.0
    ,6.00,840,1.45,1.40,4.09,6.38,840,13.650,61.5,31.5 ,5.63,0.0,0.0,0.0,0.0
    ,7.13,840,1.45,1.50,4.03,7.52,840,13.650,61.5,31.5 ,6.75,0.0,0.0,0.0,0.0
    ,8.27,840,1.50,1.50,4.09,8.64,840,13.510,61.5,31.5 ,7.89,0.0,0.0,0.0,0.0
    ,9.41,840,1.50,1.55,4.03,9.77,840,13.650,61.5,31.5 ,9.01,0.0,0.0,0.0,0.0
    ,10.53,840,1.55,1.50,4.23,10.89,840,13.720,61.5,31 .5,10.16,0.0,0.0,0.0,0.0
    ,11.65,840,1.55,1.60,4.23,12.01,840,13.720,61.5,31 .5,11.28,0.0,0.0,0.0,0.0
    ,12.77,840,1.50,1.50,4.09,13.17,840,13.650,61.5,31 .5,12.38,0.0,0.0,0.0,0.0
    ,13.92,840,1.45,1.40,4.09,14.29,840,13.720,61.5,31 .5,13.53,0.0,0.0,0.0,0.0
    ,15.04,840,1.50,1.50,4.23,15.42,840,13.580,61.5,31 .5,14.65,0.0,0.0,0.0,0.0
    ,16.17,840,1.45,1.50,4.03,16.56,840,13.720,61.5,31 .5,15.80,0.0,0.0,0.0,0.0
    ,17.31,840,1.50,1.55,4.17,17.69,840,13.720,61.5,31 .5,16.94,0.0,0.0,0.0,0.0
    ,18.44,840,1.50,1.50,4.17,18.83,840,13.650,61.5,31 .5,18.06,0.0,0.0,0.0,0.0
    ,19.58,840,1.45,1.40,3.96,19.95,840,13.650,61.5,31 .5,19.20,0.0,0.0,0.0,0.0
    ,20.70,840,1.50,1.50,4.17,21.08,840,13.720,61.5,31 .5,20.32,0.0,0.0,0.0,0.0
    ,21.84,840,1.45,1.55,4.03,22.22,840,13.650,61.5,31 .5,21.47,0.0,0.0,0.0,0.0
    ,22.99,840,1.50,1.45,4.23,23.37,840,13.720,61.5,31 .5,22.62,0.0,0.0,0.0,0.0
    ,24.11,840,1.60,1.60,4.37,24.51,880,13.720,61.5,31 .5,23.74,0.0,0.0,0.0,0.0
    ,25.26,840,1.55,1.50,4.23,25.63,840,13.650,61.5,31 .5,24.87,0.0,0.0,0.0,0.0
    ,26.38,880,1.55,1.50,4.37,26.75,840,13.650,61.5,31 .5,25.99,0.0,0.0,0.0,0.0
    ,27.50,840,1.55,1.55,4.23,27.87,840,13.580,61.5,31 .5,27.13,0.0,0.0,0.0,0.0
    ,28.62,840,1.55,1.55,4.23,29.00,840,13.650,61.5,31 .5,28.25,0.0,0.0,0.0,0.0
    ,29.74,880,1.60,1.60,4.44,30.12,840,13.720,61.5,31 .5,29.37,0.0,0.0,0.0,0.0
    ,30.87,840,1.55,1.55,4.31,31.24,840,13.650,61.5,31 .5,30.49,0.0,0.0,0.0,0.0
    ,32.01,880,1.50,1.45,4.31,32.38,840,13.650,61.5,31 .5,31.63,0.0,0.0,0.0,0.0
    ,33.15,840,1.55,1.55,4.31,33.53,840,13.650,61.5,31 .5,32.76,0.0,0.0,0.0,0.0
    ,34.30,840,1.55,1.50,4.31,34.68,840,13.580,61.5,31 .5,33.91,0.0,0.0,0.0,0.0
    ,35.42,840,1.55,1.55,4.31,35.80,840,13.650,61.5,31 .5,35.05,0.0,0.0,0.0,0.0
    ,36.57,840,1.55,1.50,4.23,36.94,840,13.650,61.5,31 .5,36.18,0.0,0.0,0.0,0.0
    ,37.69,840,1.60,1.65,4.44,38.07,840,13.720,61.5,33 .0,37.30,0.0,0.0,0.0,0.0
    ,38.82,840,1.55,1.50,4.23,39.21,840,13.650,61.5,33 .0,38.46,0.0,0.0,0.0,0.0
    ,39.98,840,1.50,1.45,4.23,40.36,840,13.650,61.5,33 .0,39.59,0.0,0.0,0.0,0.0
    ,41.10,840,1.50,1.55,4.17,41.48,840,13.510,61.5,33 .0,40.73,0.0,0.0,0.0,0.0
    ,42.22,840,1.55,1.60,4.31,42.58,840,13.650,61.5,33 .0,41.85,0.0,0.0,0.0,0.0
    ,43.35,840,1.55,1.50,4.17,43.72,840,13.580,61.5,33 .0,42.97,0.0,0.0,0.0,0.0
    ,44.47,840,1.55,1.60,4.23,44.86,840,13.650,61.5,33 .0,44.10,0.0,0.0,0.0,0.0
    ,45.61,840,1.50,1.55,4.17,45.99,840,13.650,61.5,33 .0,45.24,0.0,0.0,0.0,0.0
    ,46.73,840,1.55,1.50,4.31,47.11,840,13.650,61.5,33 .0,46.36,0.0,0.0,0.0,0.0
    ,47.88,840,1.55,1.55,4.31,48.25,840,13.650,61.5,33 .0,47.49,0.0,0.0,0.0,0.0
    ,49.01,840,1.55,1.60,4.37,49.38,840,13.650,61.5,33 .0,48.63,0.0,0.0,0.0,0.0
    ,50.17,840,1.50,1.55,4.09,50.55,840,13.650,61.5,33 .0,49.77,0.0,0.0,0.0,0.0
    ,51.32,840,1.55,1.55,4.37,51.70,880,13.650,61.5,33 .0,50.95,0.0,0.0,0.0,0.0
    ,52.45,840,1.55,1.60,4.17,52.84,840,13.650,61.5,33 .0,52.07,0.0,0.0,0.0,0.0
    1,53.61,840,1.55,1.60,4.37,53.99,840,13.650,61.5,3 3.0,53.22,0.0,0.0,0.0,0.0
    ,54.74,760,2.95,4.80,7.22,55.11,1280,13.650,61.5,3 3.0,54.36,0.0,0.0,0.0,0.0
    ,55.86,1240,3.95,3.75,15.76,56.23,1680,13.650,61.5 ,33.0,55.48,0.0,0.0,0.0,0.0
    ,56.98,1160,1.80,2.15,6.87,57.36,1080,13.650,61.5, 31.5,56.61,0.0,0.0,0.0,0.0
    ,58.10,1040,2.45,2.45,8.26,58.48,1000,13.650,61.5, 33.0,57.73,0.0,0.0,0.0,0.0
    ,59.24,1000,3.40,3.30,10.90,59.62,1160,13.720,61.5 ,33.0,58.85,0.0,0.0,0.0,0.0
    ,60.37,1480,3.45,3.55,16.59,60.74,1680,13.650,61.5 ,31.5,59.99,0.0,0.0,0.0,0.0
    ,61.48,2080,3.80,3.80,25.42,61.86,2320,13.580,61.5 ,31.5,61.11,0.0,0.0,0.0,0.0
    ,62.61,2760,4.30,4.55,37.08,63.00,3120,13.580,61.5 ,31.5,62.24,0.0,0.0,0.0,0.0
    ,63.75,2720,0.55,0.45,5.28,64.13,2040,13.650,61.5, 31.5,63.36,0.0,0.0,0.0,0.0
    ,64.87,1560,1.20,0.85,6.04,65.24,1560,13.510,61.5, 31.5,64.50,0.0,0.0,0.0,0.0
    ,66.02,1280,0.95,0.95,3.89,66.39,1160,13.650,61.5, 31.5,65.64,0.0,0.0,0.0,0.0
    ,67.17,960,1.30,1.45,4.03,67.54,840,13.580,61.5,33 .0,66.77,0.0,0.0,0.0,0.0
    ,68.31,880,2.10,1.70,5.97,68.71,960,13.650,61.5,33 .0,67.94,0.0,0.0,0.0,0.0
    ,69.46,880,2.60,4.35,7.64,69.83,1400,13.650,61.5,3 4.5,69.09,0.0,0.0,0.0,0.0
    ,70.58,1880,3.40,2.75,20.69,70.96,1400,13.650,61.5 ,31.5,70.19,0.0,0.0,0.0,0.0
    ,71.71,1640,3.25,3.50,17.36,72.08,1880,13.650,61.5 ,31.5,71.33,0.0,0.0,0.0,0.0
    ,72.85,2400,4.10,4.10,31.94,73.23,2760,13.650,61.5 ,31.5,72.45,0.0,0.0,0.0,0.0
    ,73.99,3240,2.70,2.85,27.98,74.37,2880,13.650,61.5 ,30.0,73.62,0.0,0.0,0.0,0.0
    ,75.12,2040,3.60,3.60,23.82,75.51,2160,13.650,61.5 ,31.5,74.75,0.0,0.0,0.0,0.0
    ,76.24,2040,3.95,3.95,26.11,76.63,2120,13.580,61.5 ,31.5,75.87,0.0,0.0,0.0,0.0
    ,77.38,2240,3.85,3.75,27.71,77.75,2280,13.650,61.5 ,31.5,76.99,0.0,0.0,0.0,0.0
    ,78.51,2400,3.65,3.60,28.19,78.88,2480,13.720,61.5 ,31.5,78.13,0.0,0.0,0.0,0.0
    ,79.62,2600,3.50,3.40,29.09,80.00,2600,13.650,61.5 ,31.5,79.25,0.0,0.0,0.0,0.0
    ,80.75,2520,1.20,1.20,9.93,81.14,2480,13.580,61.5, 31.5,80.38,0.0,0.0,0.0,0.0
    ,81.89,2320,0.70,0.80,5.48,82.27,2240,13.650,61.5, 31.5,81.50,0.0,0.0,0.0,0.0
    ,83.04,2040,1.05,1.05,6.87,83.41,1960,13.580,61.5, 33.0,82.66,0.0,0.0,0.0,0.0
    ,84.16,1800,2.05,2.65,11.39,84.53,1800,13.650,61.5 ,33.0,83.78,0.0,0.0,0.0,0.0
    ,85.30,2120,5.30,5.45,36.11,85.68,2320,13.650,61.5 ,31.5,84.91,0.0,0.0,0.0,0.0
    ,86.43,2720,6.95,7.10,60.28,86.83,3000,13.510,61.5 ,31.5,86.06,0.0,0.0,0.0,0.0
    ,87.58,3640,1.80,2.65,29.58,87.97,3320,13.650,61.5 ,30.0,87.20,0.0,0.0,0.0,0.0
    ,88.72,2640,0.65,0.70,5.69,89.09,2320,13.650,61.5, 30.0,88.33,0.0,0.0,0.0,0.0
    ,89.86,2360,6.10,6.15,45.76,90.22,2440,13.580,61.5 ,31.5,89.47,0.0,0.0,0.0,0.0
    ,90.97,2600,7.25,7.30,60.76,91.34,2800,13.440,61.5 ,31.5,90.61,0.0,0.0,0.0,0.0
    ,92.09,2800,0.95,0.55,8.82,92.48,2680,13.580,61.5, 28.5,91.73,0.0,0.0,0.0,0.0
    ,93.23,2440,0.60,0.60,4.72,93.61,2320,13.580,63.0, 31.5,92.85,0.0,0.0,0.0,0.0
    ,94.35,2000,0.75,0.75,4.79,94.72,1840,13.580,63.0, 31.5,93.98,0.0,0.0,0.0,0.0
    ,95.49,1520,0.85,0.80,4.31,95.85,1400,13.580,63.0, 33.0,95.10,0.0,0.0,0.0,0.0
    ,96.61,1080,1.25,1.45,4.31,96.99,920,13.580,63.0,3 3.0,96.24,0.0,0.0,0.0,0.0
    ,97.76,920,1.45,1.45,4.44,98.14,920,13.580,63.0,33 .0,97.37,0.0,0.0,0.0,0.0
    ,98.88,1040,1.25,1.15,4.31,99.26,1040,13.580,63.0, 33.0,98.51,0.0,0.0,0.0,0.0
    ,100.01,1480,3.20,3.30,15.21,100.38,1480,13.580,63 .0,34.5,99.63,0.0,0.0,0.0,0.0
    ,101.13,2000,4.60,4.60,29.23,101.50,2320,13.650,63 .0,33.0,100.75,0.0,0.0,0.0,0.0
    ,102.25,3080,5.10,5.15,50.07,102.62,3480,13.580,63 .0,31.5,101.88,0.0,0.0,0.0,0.0
    ,103.37,3640,0.90,0.55,10.90,103.76,3240,13.650,63 .0,30.0,103.00,0.0,0.0,0.0,0.0
    ,104.49,2400,4.55,4.75,34.51,104.88,2520,13.510,63 .0,31.5,104.12,0.0,0.0,0.0,0.0
    ,105.63,2800,5.05,5.10,44.93,106.00,2920,13.580,63 .0,31.5,105.24,0.0,0.0,0.0,0.0
    ,106.76,3200,5.70,5.80,58.26,107.13,3360,13.650,63 .0,31.5,106.38,0.0,0.0,0.0,0.0
    ,107.88,3680,6.00,6.10,70.21,108.25,3840,13.580,63 .0,31.5,107.52,0.0,0.0,0.0,0.0
    ,109.02,4080,3.05,2.35,44.17,109.42,3560,13.580,63 .0,31.5,108.64,0.0,0.0,0.0,0.0
    ,110.17,2720,4.35,4.45,37.98,110.55,2640,13.650,63 .0,31.5,109.79,0.0,0.0,0.0,0.0
    ,111.31,2720,5.35,5.30,47.08,111.67,2760,13.650,63 .0,33.0,110.92,0.0,0.0,0.0,0.0
    ,112.43,2880,5.90,5.80,54.31,112.79,2920,13.510,63 .0,33.0,112.04,0.0,0.0,0.0,0.0
    ,113.55,3040,6.20,6.25,60.21,113.93,3120,13.580,63 .0,33.0,113.18,0.0,0.0,0.0,0.0
    ,114.71,3200,6.40,6.45,65.42,115.11,3280,13.580,64 .5,33.0,114.33,0.0,0.0,0.0,0.0
    ,115.87,3240,4.30,4.10,45.14,116.25,3280,13.650,64 .5,31.5,115.48,0.0,0.0,0.0,0.0
    ,117.00,2360,0.75,0.85,5.83,117.37,2240,13.650,64. 5,31.5,116.62,0.0,0.0,0.0,0.0
    2,118.15,2840,0.65,0.60,5.97,118.52,3120,13.650,64 .5,33.0,117.77,0.0,0.0,0.0,0.0
    ,119.27,3760,0.75,0.80,9.44,119.64,3840,13.510,64. 5,33.0,118.91,0.0,0.0,0.0,0.0
    ,120.39,4080,8.55,8.55,110.90,120.78,4320,13.510,6 4.5,33.0,120.03,0.0,0.0,0.0,0.0
    ,121.51,4720,8.90,8.80,134.79,121.90,4960,13.230,6 4.5,34.5,121.15,0.0,2.2,0.0,0.0
    ,122.65,5400,8.25,8.25,142.36,123.02,5600,13.440,6 4.5,36.0,122.26,0.0,2.2,0.0,0.0
    ,123.78,5960,7.55,7.50,143.82,124.17,6120,13.370,6 4.5,37.5,123.40,0.0,1.5,0.0,0.0
    ,124.92,6440,7.15,7.15,146.59,125.30,6560,13.370,6 4.5,39.0,124.54,0.0,0.7,0.0,0.0
    ,126.07,6800,6.70,6.70,145.56,126.46,6880,13.300,6 4.5,42.0,125.70,0.0,0.7,0.0,0.0
    ,127.21,6280,0.70,0.75,14.17,127.59,4480,13.440,64 .5,40.5,126.84,0.0,0.0,0.0,0.0
    ,128.34,4640,8.75,8.55,129.72,128.71,4520,13.580,6 4.5,42.0,127.98,0.0,0.0,0.0,0.0
    ,129.46,4080,0.70,0.75,9.51,129.83,3840,13.580,64. 5,37.5,129.08,0.0,0.0,0.0,0.0
    ,130.58,3320,0.70,0.70,7.78,130.97,3080,13.580,64. 5,37.5,130.22,0.0,0.0,0.0,0.0
    ,131.72,2720,0.65,0.60,5.69,132.10,2520,13.580,64. 5,37.5,131.35,0.0,0.0,0.0,0.0
    ,132.86,2200,0.80,0.80,5.62,133.24,2040,13.580,66. 0,37.5,132.49,0.0,0.0,0.0,0.0
    ,134.01,1920,0.90,1.00,5.34,134.37,1880,13.650,66. 0,37.5,133.61,0.0,0.0,0.0,0.0
    ,135.13,1920,3.65,3.65,22.43,135.49,2920,13.580,66 .0,37.5,134.74,0.0,0.0,0.0,0.0
    ,136.26,3120,2.45,2.50,24.44,136.65,2960,13.580,66 .0,36.0,135.88,0.0,0.0,0.0,0.0
    ,137.40,3280,7.40,7.45,77.64,137.78,3560,13.440,66 .0,37.5,137.03,0.0,0.0,0.0,0.0
    ,138.55,4160,9.10,9.15,119.65,138.93,4400,13.510,6 6.0,37.5,138.17,0.0,0.0,0.0,0.0
    ,139.69,4880,8.60,8.65,133.89,140.07,5160,13.440,6 6.0,39.0,139.30,0.0,0.0,0.0,0.0
    ,140.82,5640,7.90,7.90,142.43,141.19,5840,13.370,6 6.0,42.0,140.44,0.0,0.0,0.0,0.0
    ,141.99,6240,7.30,7.25,146.81,142.37,6440,13.370,6 6.0,45.0,141.59,0.0,0.0,0.0,0.0
    ,143.16,6800,6.80,6.80,145.69,143.54,6920,13.300,6 6.0,48.0,142.77,0.0,0.0,0.0,0.0
    ,144.29,7120,6.60,6.60,149.93,144.69,7120,13.370,6 6.0,49.5,143.92,0.0,0.0,0.0,0.0
    ,145.48,4560,7.65,7.60,111.94,145.86,4680,13.440,6 6.0,48.0,145.11,0.0,0.0,0.0,0.0
    ,146.60,4880,8.55,8.55,133.33,146.98,4960,13.370,6 6.0,49.5,146.23,0.0,0.0,0.0,3.0
    ,147.73,5160,8.45,8.40,138.75,148.10,5240,13.300,6 6.0,51.0,147.35,0.0,0.0,0.0,3.0
    ,148.85,5160,2.55,2.65,46.04,149.22,5240,13.370,66 .0,51.0,148.47,0.0,0.0,0.0,3.0
    ,149.97,4960,0.75,0.75,12.15,150.36,4800,13.510,67 .5,45.0,149.60,0.0,0.0,0.0,0.0
    ,151.11,4400,0.75,0.80,10.83,151.49,4320,13.510,67 .5,43.5,150.74,0.0,0.0,0.0,0.0
    ,152.24,4000,0.70,0.70,9.37,152.63,3800,13.580,67. 5,42.0,151.86,0.0,0.0,0.0,0.0
    ,153.38,3520,0.70,0.65,7.84,153.75,3400,13.580,67. 5,42.0,152.99,0.0,0.0,0.0,0.0
    ,154.50,3080,0.65,0.65,6.67,154.87,2960,13.580,67. 5,40.5,154.11,0.0,0.0,0.0,0.0
    ,155.62,2760,0.60,0.60,5.28,156.00,2680,13.650,69. 0,40.5,155.25,0.0,0.0,0.0,0.0
    ,156.77,1680,1.20,1.15,6.73,157.15,2120,13.580,69. 0,40.5,156.39,0.0,0.0,0.0,0.0
    ,157.91,3480,0.35,0.35,4.31,158.29,3280,13.580,69. 0,40.5,157.52,0.0,0.0,0.0,0.0
    ,159.04,3040,0.60,0.55,5.83,159.41,2920,13.650,69. 0,40.5,158.66,0.0,0.0,0.0,0.0
    ,160.16,2920,4.40,4.85,41.11,160.53,2960,13.440,69 .0,39.0,159.78,0.0,0.0,0.0,0.0
    ,161.28,3360,9.10,9.15,97.84,161.67,3640,13.440,69 .0,37.5,160.91,0.0,0.0,0.0,2.2
    ,162.42,4160,9.05,9.05,120.69,162.80,4440,13.440,6 7.5,37.5,162.05,0.0,0.0,0.0,2.2
    ,163.60,4120,0.60,0.60,8.12,163.98,3840,13.580,69. 0,37.5,163.19,0.0,0.0,0.0,0.0
    ,164.77,3200,0.65,0.60,6.59,165.15,2920,13.580,69. 0,37.5,164.38,0.0,0.0,0.0,0.0
    ,165.92,2400,0.65,0.65,5.14,166.29,2280,13.580,69. 0,37.5,165.54,0.0,0.0,0.0,0.0
    ,167.07,2040,1.30,1.55,8.61,167.46,2080,13.510,69. 0,39.0,166.69,0.0,0.0,0.0,0.0
    ,168.21,2200,5.45,5.55,38.68,168.59,2400,13.510,67 .5,37.5,167.84,0.0,0.0,0.0,1.5
    ,169.36,3000,7.60,7.60,72.22,169.74,3280,13.580,67 .5,37.5,168.98,0.0,0.0,0.0,1.5
    ,170.50,4000,8.95,8.85,114.51,170.88,4400,13.370,6 7.5,39.0,170.11,0.0,0.0,0.0,1.5
    ,171.62,3760,0.50,0.50,6.18,171.98,3240,13.650,67. 5,37.5,171.25,0.0,0.0,0.0,0.7
    ,172.75,3200,3.20,3.15,32.78,173.12,3280,13.580,67 .5,37.5,172.37,0.0,0.0,0.0,0.7
    ,173.87,3360,2.95,2.95,31.53,174.26,3400,13.580,69 .0,37.5,173.50,0.0,0.0,0.0,0.7
    ,175.01,3680,8.80,9.00,102.84,175.39,3840,13.440,6 9.0,39.0,174.64,0.0,0.0,2.2,0.7
    ,176.13,4120,9.10,9.10,120.42,176.51,4280,13.300,6 9.0,40.5,175.76,0.0,0.0,0.0,0.0
    ,177.26,4640,8.80,8.75,129.93,177.63,4720,13.440,6 9.0,42.0,176.88,0.0,0.0,0.0,0.0
    ,178.38,5000,8.50,8.45,135.42,178.75,5120,13.230,6 9.0,43.5,178.00,0.0,0.0,0.0,0.0
    ,179.50,5400,8.20,8.25,140.69,179.89,5560,13.370,6 9.0,45.0,179.13,0.0,0.0,0.0,0.0
    ,180.64,5040,8.35,8.50,133.47,181.01,4160,13.370,6 9.0,46.5,180.27,0.0,0.0,0.0,0.0
    ,181.76,4200,0.55,0.50,7.43,182.14,4000,13.510,69. 0,42.0,181.37,0.0,0.0,0.0,0.0
    ,182.89,3680,0.70,0.70,8.61,183.26,3520,13.580,69. 0,40.5,182.51,0.0,0.0,0.0,0.0
    ,184.03,3200,0.60,0.60,6.53,184.40,3040,13.580,69. 0,40.5,183.65,0.0,0.0,0.0,0.0
    ,185.15,2240,0.70,0.75,5.21,185.53,3600,13.580,69. 0,40.5,184.78,0.0,0.0,0.0,0.0
    ,186.30,3360,0.55,0.60,5.97,186.69,3240,13.580,69. 0,40.5,185.92,0.0,0.0,0.0,0.0
    ,187.44,3040,0.55,0.55,5.56,187.82,2480,13.580,69. 0,40.5,187.05,0.0,0.0,0.0,0.0
    ,188.57,3720,0.40,0.40,5.28,188.94,4040,13.580,69. 0,40.5,188.19,0.0,0.0,0.0,0.0
    ,189.69,3920,0.55,0.55,7.22,190.06,3880,13.580,69. 0,40.5,189.31,0.0,0.0,0.0,0.0
    ,190.81,3800,0.60,0.60,7.50,191.20,3760,13.580,69. 0,40.5,190.44,0.0,0.0,0.0,0.0
    ,191.95,3720,0.60,0.55,7.36,192.33,3640,13.580,69. 0,37.5,191.58,0.0,0.0,0.0,0.0
    ,193.07,3400,0.60,0.60,6.46,193.45,3200,13.580,69. 0,39.0,192.70,0.0,0.0,0.0,0.0
    ,194.20,3000,0.55,0.60,5.48,194.57,2960,13.580,69. 0,39.0,193.82,0.0,0.0,0.0,0.0
    ,195.34,2880,0.55,0.55,5.21,195.72,2840,13.580,69. 0,39.0,194.96,0.0,0.0,0.0,0.0
    ,196.48,2640,0.55,0.55,4.72,196.86,2440,13.580,69. 0,39.0,196.11,0.0,0.0,0.0,0.0
    ,197.61,2040,0.75,0.75,5.00,198.00,1840,13.580,67. 5,39.0,197.24,0.0,0.0,0.0,0.0
    ,198.75,1560,0.95,1.25,4.79,199.13,1200,13.580,67. 5,39.0,198.38,0.0,0.0,0.0,0.0
    ,199.87,1120,1.35,1.05,4.93,200.23,1400,13.510,67. 5,39.0,199.50,0.0,0.0,0.0,0.0
    ,201.00,1440,0.60,0.60,2.84,201.39,1040,13.580,67. 5,39.0,200.62,0.0,0.0,0.0,0.0
    ,202.14,1480,4.55,4.60,21.39,202.54,1920,13.580,67 .5,37.5,201.77,0.0,0.0,0.0,0.0
    ,203.29,2920,6.35,6.45,59.09,203.66,3600,13.510,67 .5,36.0,202.92,0.0,0.0,0.0,0.0
    ,204.41,5200,8.25,8.25,136.46,204.79,5960,13.440,6 7.5,36.0,204.03,0.0,0.0,0.0,0.0
    ,205.55,5840,0.50,0.50,9.31,205.91,5200,13.370,67. 5,36.0,205.16,0.0,0.0,0.0,0.0
    ,206.68,4080,3.75,3.45,50.34,207.05,4280,13.580,67 .5,36.0,206.30,0.0,0.0,0.0,0.0
    ,207.79,4080,0.70,0.65,9.09,208.17,3880,13.580,67. 5,36.0,207.42,0.0,0.0,0.0,0.0
    ,208.94,3720,0.60,0.60,7.29,209.32,3600,13.510,67. 5,37.5,208.57,0.0,0.0,0.0,0.0
    ,210.06,3280,0.60,0.60,6.46,210.44,3120,13.580,67. 5,37.5,209.69,0.0,0.0,0.0,0.0
    ,211.18,2920,0.60,0.60,5.76,211.54,2760,13.580,67. 5,37.5,210.81,0.0,0.0,0.0,0.0
    ,212.31,2440,0.60,0.60,5.00,212.68,2360,13.650,67. 5,37.5,211.93,0.0,0.0,0.0,0.0
    ,213.43,2200,1.45,1.50,10.42,213.80,2160,13.510,67 .5,37.5,213.06,0.0,0.0,0.0,0.0
    ,214.55,1960,1.90,2.10,12.15,214.94,1920,13.510,67 .5,37.5,214.18,0.0,0.0,0.0,0.0
    ,215.69,2160,4.45,4.65,30.48,216.07,2320,13.510,67 .5,37.5,215.32,0.0,0.0,0.0,0.0
    ,216.82,2800,6.85,6.95,61.39,217.19,3080,13.440,67 .5,36.0,216.44,0.0,0.0,0.0,0.0
    ,217.94,3720,9.25,9.20,110.14,218.31,4040,13.440,6 7.5,36.0,217.56,0.0,0.0,0.0,0.0
    ,219.06,4640,8.90,8.90,130.90,219.45,4920,13.440,6 7.5,37.5,218.69,0.0,0.0,0.0,0.0
    ,220.20,5440,8.25,8.25,143.06,220.60,5720,13.370,6 7.5,40.5,219.83,0.0,0.0,0.0,0.0
    ,221.37,6120,7.40,7.35,145.56,221.77,6320,13.370,6 7.5,42.0,220.97,0.0,0.0,0.0,0.0
    ,222.53,6680,6.90,6.85,146.94,222.92,6640,13.370,6 7.5,45.0,222.17,0.0,0.0,0.0,0.0
    ,223.67,4920,0.85,0.85,13.47,224.04,4200,13.580,67 .5,43.5,223.29,0.0,0.0,0.0,0.0
    ,224.77,4280,8.10,8.15,110.28,225.16,4200,13.580,6 7.5,43.5,224.41,0.0,0.0,0.0,0.0
    ,225.91,4080,6.00,6.20,77.36,226.29,4120,13.440,67 .5,42.0,225.54,0.0,0.0,0.0,0.0
    ,227.05,4240,8.85,8.90,119.79,227.43,4320,13.230,6 7.5,45.0,226.66,0.0,0.0,0.0,0.0
    ,228.17,4200,0.55,0.45,7.57,228.53,4120,13.580,67. 5,40.5,227.80,0.0,0.0,0.0,0.0
    ,229.30,3920,0.60,0.60,8.06,229.68,3800,13.580,67. 5,40.5,228.92,0.0,0.0,0.0,0.0
    ,230.42,3640,0.60,0.60,7.36,230.80,3520,13.580,69. 0,40.5,230.05,0.0,0.0,0.0,0.0
    ,231.56,3320,0.60,0.60,6.67,231.92,3240,13.510,69. 0,40.5,231.19,0.0,0.0,0.0,0.0
    ,232.68,3200,6.45,6.70,65.14,233.06,3240,13.510,69 .0,40.5,232.29,0.0,0.0,0.0,0.0
    ,233.81,3280,1.80,4.75,19.51,234.18,3160,13.580,69 .0,37.5,233.43,0.0,0.0,0.0,0.0
    ,234.95,3200,2.25,2.40,22.98,235.32,3120,13.510,69 .0,37.5,234.56,0.0,0.0,0.0,0.0
    ,236.08,3120,4.05,4.15,40.56,236.47,3120,13.510,69 .0,37.5,235.72,0.0,0.0,0.0,0.0
    ,237.24,3200,5.80,6.25,59.23,237.60,3240,13.580,69 .0,37.5,236.85,0.0,0.0,0.0,0.0
    ,238.36,3320,2.25,2.20,24.09,238.74,3400,13.580,69 .0,37.5,237.99,2.2,0.0,0.0,0.0
    ,239.86,3760,9.20,9.20,110.62,240.24,3960,13.440,6 9.0,37.5,239.50,2.2,0.0,0.0,0.0
    ,240.99,4280,3.65,3.35,53.06,241.38,4160,13.580,69 .0,36.0,240.63,1.5,0.0,0.0,0.0
    ,242.11,3920,0.55,0.60,7.29,242.50,3760,13.580,69. 0,37.5,241.75,0.0,0.0,0.0,0.0
    ,243.23,3280,0.65,0.65,6.81,243.62,2920,13.580,69. 0,37.5,242.87,0.0,0.0,0.0,0.0
    ,244.39,3240,0.50,0.50,5.28,244.77,4240,13.510,69. 0,39.0,244.00,0.0,0.0,0.0,0.0
    ,245.52,4120,0.60,0.60,8.19,245.91,4080,13.650,69. 0,39.0,245.15,0.0,0.0,0.0,0.0
    ,246.66,4240,6.45,6.65,86.46,247.03,4480,13.370,69 .0,37.5,246.29,0.0,0.0,0.0,0.0
    ,247.78,5040,8.40,8.40,136.11,248.16,5360,13.440,6 9.0,37.5,247.39,0.7,0.0,0.0,0.0
    ,248.93,5920,7.65,7.65,144.51,249.30,6160,13.440,6 9.0,37.5,248.55,0.7,0.0,0.0,0.0
    ,250.10,6640,6.90,6.95,146.25,250.48,6840,13.370,6 9.0,40.5,249.70,0.0,0.0,0.0,0.0
    ,251.30,7080,6.50,6.50,146.81,251.68,6520,13.510,6 9.0,45.0,250.91,0.0,0.0,0.0,0.0
    ,252.46,4840,8.40,8.35,129.03,252.83,4880,13.440,6 9.0,43.5,252.08,0.0,0.0,3.0,0.0
    ,253.58,4880,0.60,0.65,9.86,253.97,4720,13.510,69. 0,42.0,253.22,0.0,0.0,3.0,0.0
    ,254.72,4240,0.65,0.65,9.23,255.10,4120,13.510,69. 0,42.0,254.34,0.0,0.0,0.0,0.0
    ,255.86,3880,0.65,0.70,8.33,256.24,3720,13.580,69. 0,42.0,255.47,0.0,0.0,0.0,0.0
    ,256.99,3520,0.60,0.65,6.94,257.38,3360,13.510,69. 0,42.0,256.61,0.0,0.0,0.0,0.0
    ,258.14,3160,0.55,0.55,5.76,258.51,3040,13.580,69. 0,42.0,257.76,0.0,0.0,0.0,0.0
    ,259.28,2880,0.75,0.95,7.01,259.65,2800,13.580,69. 0,42.0,258.90,0.0,0.0,0.0,0.0
    ,260.40,2680,0.75,0.50,6.59,260.78,2720,13.580,69. 0,40.5,260.03,0.0,0.0,0.0,0.0
    ,261.54,1880,1.00,1.20,6.18,261.92,2000,13.580,70. 5,40.5,261.15,0.0,0.0,0.0,0.0
    3,262.67,2960,0.35,0.40,3.61,263.04,3240,13.580,70 .5,40.5,262.29,0.0,0.0,0.0,0.0
    ,263.79,3080,0.55,0.55,5.56,264.16,2920,13.580,70. 5,40.5,263.41,0.0,0.0,0.0,0.0
    ,264.91,2600,0.55,0.55,4.93,265.28,2440,13.510,70. 5,40.5,264.54,0.0,0.0,0.0,0.0
    ,266.03,1920,0.80,0.90,5.14,266.41,1400,13.580,69. 0,40.5,265.65,0.0,0.0,0.0,0.0
    ,267.17,1040,1.35,1.35,4.44,267.55,1080,13.510,69. 0,40.5,266.78,0.0,0.0,0.0,0.0
    ,268.30,1080,1.45,1.80,5.14,268.67,1080,13.580,69. 0,40.5,267.92,0.0,0.0,0.0,0.0
    ,269.42,1200,3.10,3.45,11.59,269.79,1360,13.510,69 .0,40.5,269.04,0.0,0.0,3.0,0.0
    ,270.54,1800,3.20,3.20,18.47,270.93,2000,13.580,69 .0,39.0,270.17,0.0,0.0,3.0,0.0
    ,271.68,1960,0.75,0.70,4.65,272.08,1480,13.650,70. 5,37.5,271.29,0.0,0.0,0.0,0.0
    ,272.83,1320,3.85,3.90,16.53,273.21,1480,13.580,70 .5,39.0,272.44,0.0,0.0,3.0,0.0
    ,273.97,1680,3.65,3.55,19.79,274.33,1760,13.580,70 .5,37.5,273.58,0.0,0.0,3.0,0.0
    ,275.10,2000,3.50,3.55,22.57,275.47,2120,13.580,70 .5,37.5,274.72,0.0,0.0,3.0,0.0
    ,276.24,2240,1.00,0.95,7.43,276.62,2240,13.510,70. 5,37.5,275.85,0.0,0.0,3.0,0.0
    ,277.40,2040,0.65,0.65,4.44,277.79,1840,13.580,70. 5,37.5,277.02,0.0,0.0,0.0,0.0
    ,278.54,1600,0.75,0.75,4.03,278.92,1520,13.580,70. 5,39.0,278.16,0.0,0.0,0.0,0.0
    ,279.68,1480,2.55,2.85,11.94,280.04,1520,13.580,70 .5,39.0,279.29,0.0,0.0,0.0,0.0
    ,280.81,1640,3.30,3.40,17.36,281.18,1720,13.580,70 .5,37.5,280.43,0.0,0.0,3.0,0.0
    ,281.93,1920,3.30,3.35,20.21,282.30,1960,13.580,70 .5,37.5,281.55,0.0,0.0,1.5,0.0
    ,283.05,2200,3.75,3.80,26.67,283.43,2320,13.580,70 .5,37.5,282.68,0.0,0.0,1.5,0.0
    ,284.17,2120,1.15,0.65,8.61,284.55,1640,13.580,70. 5,36.0,283.80,0.0,0.0,0.7,0.0
    ,285.31,1640,4.35,4.15,23.26,285.67,1680,13.580,70 .5,37.5,284.92,0.0,0.0,0.7,0.0
    ,286.44,1680,0.85,0.60,4.51,286.81,1640,13.580,70. 5,36.0,286.06,0.0,0.0,0.0,0.0
    ,287.56,1520,0.70,0.65,3.54,287.95,1520,13.650,70. 5,37.5,287.19,0.0,0.0,0.0,0.0
    ,288.70,1440,0.75,0.85,3.61,289.08,1400,13.580,70. 5,39.0,288.33,0.0,0.0,0.0,0.0
    ,289.82,1360,1.15,1.35,5.14,290.20,1280,13.510,70. 5,39.0,289.45,0.0,0.0,0.0,0.0
    ,290.94,1240,1.05,0.90,4.31,291.31,1240,13.580,70. 5,39.0,290.57,0.0,0.0,0.0,0.0
    ,292.07,1000,1.35,1.35,4.31,292.44,1240,13.510,70. 5,39.0,291.69,0.0,0.0,0.0,0.0
    ,293.19,1280,0.75,0.85,3.19,293.58,1200,13.580,70. 5,39.0,292.83,0.0,0.0,0.0,0.0
    ,294.33,920,1.20,1.20,3.61,294.71,880,13.510,70.5, 39.0,293.96,0.0,0.0,0.0,0.0
    ,295.46,920,1.30,1.25,3.89,295.85,880,13.440,70.5, 39.0,295.08,0.0,0.0,0.0,0.0
    ,296.60,880,1.45,1.40,4.23,296.97,880,13.510,70.5, 39.0,296.22,0.0,0.0,0.0,0.0
    ,297.72,840,1.50,1.50,4.09,298.09,880,13.510,70.5, 39.0,297.34,0.0,0.0,0.0,0.0
    ,298.84,840,1.45,1.50,4.03,299.21,840,13.510,70.5, 39.0,298.47,0.0,0.0,0.0,0.0
    Aug 2011
    977
    Any one able to point out what's going on.. Can run logs again with groups up to 25 atm. Maybe throttle position along side maf and injection as well as this enrich and part throttle thing.. I guess this is down to mapping.?
  1. 96 TDI Log file if someone wouldnt mind having a nosey :)
    By jonnycraig in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd March 2011, 03:03
  2. MAF readings logged.... confused!!
    By markymark1984 in forum VCDS (formerly VAG-COM) forum
    Last Post: 14th October 2007, 10:44
  3. whats yours reading??
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th March 2007, 21:21
  4. whats your mpg reading?...and whats the max youve had?
    By *Rashs3* in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2006, 09:18
  5. What car magazines do you read?
    By necroeire in forum General Chat
    Last Post: 5th August 2005, 14:19
