Volks AutosChris Nott
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Help make sense of scan please
    Hi.
    I have a A4 B6. And am having a recent problem with a ABS error flashing up on the dash.
    Ive scanned the car with the following resuts.
    Can anyone translate whats wrong ?
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Sunday,01,July,2012,14:03:13:59382
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E22A175460 Mileage: 195630km/121558miles
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 8E0 909 518 HW: 8E0 909 018
    Component: 1.8L R4/5VT 0001
    Coding: 0011501
    Shop #: WSC 63251 000 00000
    VCID: EDDFB922F78A5F1
    2 Faults Found:
    16523 - Oxygen (Lambda) Sensor B1 S2
    P0139 - 004 - Response too Slow - Intermittent
    18057 - Powertrain Data Bus
    P1649 - 008 - Missing Message from ABS Controller - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 1726
    Coding: 04275
    Shop #: WSC 06335
    VCID: E5CFC1027F7A671
    3 Faults Found:
    18256 - Please check DTC Memory of Engine Controller
    P1848 - 35-10 - - Intermittent
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    65535 - Internal Control Module Memory Error
    00-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043
    Component: A4 Klimaautomat 0712
    Coding: 00000
    Shop #: WSC 63351
    VCID: DEBDEEEE5A2C349
    No fault code found.
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 63351
    VCID: 3469EC4604204E9
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655
    Component: Airbag 8.4E 4001
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: F4E9AC4694A08E9
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0308
    Coding: 00012
    Shop #: WSC 63351
    VCID: 366DD64E125C5C9
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 G
    Component: KOMBI+WEGFAHRS. RB4 D25
    Coding: 00400
    Shop #: WSC 00502
    VCID: 2D5FF922E70A1F1
    WAUZZZ8E22A175460 AUZ6Z0A0263101
    1 Fault Found:
    01316 - ABS Control Module
    49-10 - No Communications - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0504
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDBB73A999E511
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 AH
    Component: Komfortgerát T9F 0619
    Coding: 07147
    Shop #: WSC 00665
    VCID: 77F31B4A55D6651
    Subsystem 1 - Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0002
    Subsystem 2 - Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0002
    Subsystem 3 - Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0002
    2 Faults Found:
    01561 - Left Rear Door
    61-00 - Won't De-Safe
    01562 - Right Rear Door
    61-10 - Won't De-Safe - Intermittent
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 152
    Component: chorus II GRO 0007
    Coding: 00002
    Shop #: WSC 63351
    VCID: DDBFE9E2572A2F1
    1 Fault Found:
    01317 - Control Module in Instrument Cluster (J285)
    Thanks for all your help.
    Andi
    27,028
    ABS controller seems to have a power issue maybe & module problem, I would check all cables & fuses to the unit 1st, then clear errors & rescan.
  1. Help With Upgrading A3 ICE Please
    By J7-AUDIA3 in forum In-Car Entertainment
    Last Post: 29th November 2007, 09:45
  2. where's the n80 and help with vag-com codes please.....
    By shufti in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 9th August 2007, 14:18
  3. Help for Phatbox cradle psu please...
    By FrankScorpio in forum In-Car Entertainment
    Last Post: 27th July 2007, 06:58
  4. Help with a part code please?
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2004, 16:48
  5. Help! Advice on Spare Key please!
    By AndyMcUK in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th November 2003, 20:33
