Sky InsuranceVolks Autos
    Jun 2012
    East Ayrshire
    Question A4 8K SALOON HARMON PHONE
    Bought a harmon (original Audi) phone and bluetooth with wiring harness cos I was getting the "telephone not installed" on the screen. Fitted the wiring and put the b/tooth module behind glovebox. Had it at a few VW Audi specialists and Sandra kindly at the drop of a hat organised a late meeting with Eddie who worked tirelessly to code this. Problem is it works with the phone speakers work it mutes music I can talk and be heard and the call comes through the speakers but it doesn't display on the screen??? Any ideas welcome. Had it in at Audi Ayr and no joy. Any VCDS gurus out there can help I'd be delighted to hear. The wiring is as follows. Switched+/earth. Can high to pin 9 and low to pin 10 the rest is plug n play.
    26,776
    Is this a copper based wiring only or did it have a fibre optic cable aswell?
    Jun 2012
    East Ayrshire
    copper based. had someone connect to it with vcds and it recognised it was there but when code was changed ans he hit do it the code was rejected???
    26,776
    According to wiring, there's 4 can wires, not 2, the pins 9/10 connect to the radio 12 pin connector, then there's pin 17/18 to connect aswell, it doesnt denote these as being independent as in one connection or the other, so maybe it requires these aswell.
  1. RS4 Exhaust & Cat on an S4 Saloon......?
    By ibbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th October 2003, 18:24
  2. RS4 Exhaust & Cats on an S4 Saloon......
    By ibbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th October 2003, 18:17
  3. Smoked Rear Light Lenses for 2003 A6 Saloon
    By cliffcartwright in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 8th October 2003, 14:28
  4. does the A4 saloon have fold down rear seats?
    By remfanuk in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2003, 11:15
  5. Phone Socket
    By AndybS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th July 2003, 10:00
Tags for this Thread
