Badger5Chris Nott
    zippyijk's Avatar
    Dec 2009
    Dublin, Ireland
    70
    Audi A3 8P2 VCDS Coding
    Well hello hello Eventually got a RT VCDS cable (from Nigel) so I've been messing about with some changes already.
    I'm not sure how to (or if I can) post attachments so here's a link to an .xls (Audi A3_VCDS Menus.xls 7.31MB) that I made earlier.
    Basically its just to keep track of my settings but its screen grabs of all the modules on my car and all of their adaption/coding/codingII sections.
    Might be helpful to someone else if trying to find that specific byte/bit.
    (MODS if its not OK to post a link please delete I won't be offended )
    http://dl.dropbox.com/u/17485710/Aud...DS%20Menus.xls
    So I've had a few changes made in the past which you'll probably notice from the excel file attached.
    There's a few I'd be interested in doing but not sure exactly how or if they're possible.
    First thing is that I have heated seats in front/rear installed from factory but in
    09-Cent. Elect
    Coding
    Byte 2 - Bit 7 (Seat Heating Installed)
    This is not ticked?? Now my heated seats work perfectly but just wondering why its not ticked?
    Next is TPMS
    I know there are 2 types of TPMS, one with the sensors at each wheel and one that is ABS based.
    I know that it can be controlled from the DIS or from a button...like my Octy vRS had.
    I also know on my Yeti that even without the button it can be enabled without the button/DIS and reset from VCDS.
    It takes approx 1 hr of driving to set its new values......details can be found on briskoda.
    The disadvantage of that is the fact you need VCDS to reset it every time you get a flat/puncture but I'd not be worried about that.
    So is it possible to enable TPMS on an 05 plate A3 8P2 Sportback?
    If I -16384 from coding in my ABS module, that should change to "with TPMS"
    Then in CAN Gateway in Coding if I enable Byte 01 bit 7 (65-Tyre Pressure Monitoring) that would show up TPMS module, but that doesn't sound right, that sounds like the other system that needs a module for the sensors on the wheels?
    I can't see anything in my Instruments module but I didn't search each channel in adaption yet.
    TPMS can then be reset from Adaptation menu on ABS module.
    I then drive until TPMS light deactivates, like on Yeti?
    2005 Audi A3 Sportback 2.0TDI DSG S-line
    2012 Skoda Yeti 1.6TDI Greenline II Elegance
    27,089
    Ignore the seat heating box, its not related & tpms on that year is possible if abs supports, try coding & see if accepts, then try to check for readings changing in MB's 7 dont enable tpms in gateway as its also not related to the abs version.
  1. Audi DRLs now not working - VCDS coding error
    By vagcat in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th July 2011, 20:48
  2. VCDS coding for tails
    By tcardio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th February 2010, 17:45
  3. Help! Passenger's window won't close! VCDS Code.
    By SAiLO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2010, 01:07
  4. VCDS Codes
    By Andy Shipton in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th December 2009, 13:01
  5. Audi 80 stereo unlock code?
    By imported_elmotactics in forum In-Car Entertainment
    Last Post: 8th February 2005, 10:12
