Sky InsuranceAH Fabrications
    Jun 2007
    Norfolk
    66
    3.0 TDi - Fuel pump timing
    I have read in another forum someone checked their fuel pump timing with VCDS
    Does anyone know how to do this? also alter it if need be?
    Paul
    Jul 2007
    London
    3,235
    It's a common rail engine, no such thing available for it ! You adjust the timing on the older 2.5 Tdi engine with a VE injector pump. On the CR engine the timing is entirely controlled by the ECU...
    FOR SALE:
    Jun 2011
    Great Melton Norfolk
    1,349
    Whereabouts in Norfolk are you?
    Jun 2007
    Norfolk
    66
    Live in Norwich
  1. 2.5 v6 tdi dynamic pump timing!!!
    By Yappy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th January 2011, 22:59
  2. 2.5 TDI V6 Diesel Injection Pump Timing Woes?
    By snapdragon in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th May 2010, 11:57
  3. fuel pump questions 1.9 tdi
    By splasher in forum Diesel forum
    Last Post: 25th August 2009, 15:50
  4. 2.5 TDi fuel pump . . . . how much ? !!!!
    By Neil C in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th April 2009, 17:07
  5. how do i check tdi pump timing
    By olds_kool in forum VCDS (formerly VAG-COM) forum
    Last Post: 6th August 2008, 08:39
