Sky InsuranceAH Fabrications
    Erf
    Oct 2006
    Kingston
    233
    Any ideas how to clear this...
    Any help appreciated!
    VCDS-Lite Version: Release 1.1
    Friday, 01 June 2012, 21:35:09:5967
    Control Module Part Number: 8N0 907 379 E
    Component and/or Version: ESP 20 CAN V005
    Software Coding: 18448
    Work Shop Code: WSC 01236
    VCID: 3E0FAAB42979
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    62-00 - No or Incorrect Adjustment
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    35-10 - - - Intermittent
    Silver 2002 S3 - Alloy Mirrors - RNS-E - Parrot MKI9200 - Beesting Ariel - Stealth Catch Can - S2000 Air Filter - R32 Rear ARB
    Oyster Grey 2008 A6 Avant S-Line 2.0TDI DPF
    Jan 2012
    1,837
    27,014
    Check the sensor isnt clogged with dust or crap, also check its connector isnt damaged or crapped up.
    Angle sensor may need recalibrating or its got a fault.
    VCDS with basic setting access & measuring blocks will help with both of these issues.
    Erf
    Oct 2006
    Kingston
    233
    Cheers guys. Cleared the warning light for the ESP caused by the steering angle sensor.
    If anyone needs to to do this, the instructions are:
    Prerequisites:
    Start the vehicle.
    Turn the steering wheel one turn to the right and one turn to the left.
    Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
    If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
    Ensure that the steering wheel is not moved again.
    Keep the engine running and do not switch off the ignition.
    System voltage at least 12.0 V.
    [Select]
    [03 - Brake Electronics]
    [Coding-II - 11]
    Enter 40168, to enable the basic setting.
    [Do it!]
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a successful basic setting, field 2 should say "OK".
    [Done, Go Back]
    To make sure the basic setting was succesful, check the sensor again.
    [Measuring Blocks - 08]
    Group 004
    [Go!]
    Check field 1, the value has to be between -4.5 and +4.5 °.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
  1. Any ideas how to fit Lower boost hoses???
    By Gangeyboy1982 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2010, 19:53
  2. Any ideas how to fit short shift?
    By mrr_1990@hotmail.com in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2009, 13:44
  3. Any ideas how to stop my front wipers from juddering??
    By robbie5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th April 2008, 13:55
  4. Any idea how much....
    By kevlar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th July 2006, 10:26
  5. any ideas how to do this?
    By sdl3884 in forum The Welcome Section
    Last Post: 10th December 2004, 19:41
