AH FabricationsVolks Autos
    Jan 2012
    Cambridgeshire UK
    26
    A4 2.0T FSI codes, help needed?
    Hi,
    I have a 2005 A4 B7 2.0T FSI Quattro that i have scanned and these are the code taht have come up.
    012555 - Low Pressure Fuel regulation
    P310B - 008 - Fuel Pressure Outside Specification - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 136
    Mileage: 93543 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1309 /min
    Load: 28.2 %
    Speed: 2.0 km/h
    Temperature: 0.0°C
    Temperature: 0.0°C
    Absolute Pres.: 1030.0 mbar
    Voltage: 14.478 V
    012600 - Intake Manifold Runner Control
    P3138 - 008 - Regulation Deviation
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 99156 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3721 /min
    Load: 29.4 %
    Speed: 80.0 km/h
    Temperature: 85.0°C
    Temperature: 15.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.224 V
    008200 - Intake Manifold Flap; Bank 1
    P2008 - 001 - Electrical Malfunction
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 99156 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3717 /min
    Load: 29.4 %
    Speed: 81.0 km/h
    Temperature: 85.0°C
    Temperature: 15.0°C
    Voltage: 14.224 V
    I am under the impression that i will be needing a new intake manifold flapper valve but would this cause the fuel pressure sensor to give a fault code?
    Tim
    Jan 2012
    1,599
    Jan 2012
    Cambridgeshire UK
    26
    Thanks for the quick response.
    I would say the last one is related to the intake manifold runner control. It's starting to look like an expensive week!!
  1. Fault code help needed 2000 S3
    By fitzdog88 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2012, 22:17
  2. Changing country code help needed in Bournemouth
    By nickrex in forum VCDS (formerly VAG-COM) forum
    Last Post: 9th February 2012, 00:15
  3. Fault code help needed plz!!!
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2010, 17:41
  4. RNS-LOW coding help needed.
    By s8craig in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th April 2007, 16:35
  5. BOSE Coding - Help Needed!!
    By JamS3 in forum In-Car Entertainment
    Last Post: 8th September 2006, 14:12
