Badger5Volks Autos
Results 1 to 8 of 8
    May 2012
    12
    skoda octavia vrs high timing pull 3rd gear run
    Ive just done some logs on my mk1 VRS, From what I can see boost and MAF look ok. TIming looks high though? What can cause this? Ive read anything over 6 is bad? Car is 100% standard. Ive attached logs of 115,020,003 and also 118,031,003. Can anyone shed any light on the issue? He has had a problem with revs not dropping when changing gear thats why we did some logs.this was done by a friend...av changed coil packs and plugs.......any info would be greatfull Attached Files
    Oct 2009
    Hull
    1,437
    Revs not dropping could be the clutch switch if you have cruise and it works your switch is fine if it doesn't then its buggered
    May 2012
    12
    i dont have cruise controll..but does the car still have it
    May 2012
    12
    can any one help as its doing my nut in now and am stuck..am fitting new clutch sensor on tuesday..what else can make the car have high pull........please,thanks
    May 2012
    12
    Quote Originally Posted by stu_m View Post
    hi mine didnt have one but my mates did..him and me dont have cruise but his has the sensor so i put it in mine and the over reving has stopped....my car is still getting timing pull at 8
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    I'd have thought he is running on crappy supermarket fuel tbh, will mess with timing a lot due to the inconsistency of the qualtties between brands
    May 2012
    12
    i use v power. but am still stuck with the timing pull..do you think a remap mite happy sort it
    May 2012
    12
    Quote Originally Posted by Byzan Pics View Post
    cheers
  1. skoda octavia vrs high timing pull
    By vrsjaw in forum General Technical / How To
    Last Post: 29th May 2012, 18:47
  2. 3rd gear log (readable this time) lol
    By sandwich1987 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2012, 17:05
  3. SKODA OCTAVIA VRS NOT STARTING
    By DIPS_A4 in forum Other Brands & Models
    Last Post: 7th November 2006, 10:05
  4. Skoda Octavia 1.9 TDI
    By geoffers93 in forum The Welcome Section
    Last Post: 23rd June 2003, 19:35
  5. Skoda Octavia 1.9 TDI
    By geoffers93 in forum Diesel forum
    Last Post: 23rd June 2003, 19:23
