Monster MotorsportEM Tuning
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    Coding Symphony II+
    Just after some advice on this as I have never used vag-com to code / make adjustments before - only ever used it to scan for fault codes.
    Basically I am upgrading the factory audio in my 2002 A4 from a Symphony II, to a Symphony II+
    I have found the following on the net;
    Audi Radio Generation II Plus - Ross-Tech Wiki
    The new unit is from America, so I need to change the country to Europe.
    The car is a 2002 A4 Avant TDi with material interior, so im guessing I will need to change to; wagon/avant and diesel engine.
    My issue is, I dont know what 0xx0xx? means, or how to get there and how to change it.
    Im taking it I go to the "radio" section of vag-com, go to adaptation - from there im lost!... Any help would be appreciated.
    Thanks.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Sep 2007
    North-East UK
    95
    Alex,
    Use the Coding button within VCDS to change the configuration. Once there you should get a help message to explain the different options that are available, but based on what you have said I would suggest a coding of 0??0221, this consists of the following:
    0 - Fixed, no options
    ? - Add the digits together depending upon what is fitted. If you have MFSW use 2, if MFSW & Telephone use 6 (2+4)
    ? - As above. If you have a CD changer use 2, if CD & Digital Sound use 3 (2+1)
    2 - Diesel engine
    2 - Avant
    1 - Europe
    I'm not familiar with the A4 radios so assume that they both work on CAN-bus, if not then you may need to make other changes to the CAN controller module to enable the radio to be identified.
    Hope this helps.
    Steve
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    Feb 2012
    Liverpool
    1,152
    Many thanks for your help - I think I understand how coding works now!
    The Symphony II+ will be retrofitted into a 2002 A4 without CANBUS using a quadlock to ISO convertor.
    Quote Originally Posted by JST_A3 View Post
    Alex,
    2 - Diesel engine
    2 - Avant
    1 - Europe
    Hope this helps.
    Steve
    - Weitec GT
    Feb 2012
    Liverpool
    1,152
    Just an update on this - the unit arrived from America, I managed to code everything apart from the region setting.
    Whenever I tried to code to Europe it came up with an error.
    Not sure if there is any way around this?
    - Weitec GT
  1. symphony II+ to rnse coding help
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2012, 10:52
  2. Coding Help, Engine module, coding 11 access key required?
    By rickypj in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 12:57
  3. HELP!! Symphony II to Symphony II+ Strange Radio Problem
    By BennyB0Y in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th May 2009, 15:46
  4. Coding a Symphony II+ Is it possible?
    By BennyB0Y in forum In-Car Entertainment
    Last Post: 10th July 2007, 01:30
  5. 8L Symphony to Symphony 2 Upgrade problems
    By shollis in forum In-Car Entertainment
    Last Post: 20th February 2007, 11:29
