AH FabricationsVolks Autos
    Apr 2012
    93
    Unhappy VAGCOM BRAKE BLEEDING
    hi all, can i bleed my brakes with vagcom? ive broke 1 of the small bleed nipples of the master cylinder while trying to bleed my brakes, and i need to no if you can bleed them through vagcom with out having to change the broken bleed nipple on the m/c. thanks..
    Aug 2008
    408
    Im sure theres a procedure on rosstechs web site m8,
    im sure its really only for complete brake refurbs?
    Still worth a look tho.
    Cal
    27,075
    Yes but the bleed nipple is to allow the fluid to come out, thats the point of bleeding as you know, you can certainly do it via vcds & bleed through the calipers, but it may not bleed the mc properly if you've introduced air into the mc circuit as such, check to see if the nipples can be replaced independently, if so replace & bleed again.
  1. Brake bleeding - how to?
    By TeKnodriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th February 2012, 21:50
  2. Brake Bleeding
    By 666markyboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2011, 11:22
  3. Brake bleeding help!
    By swatchuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st April 2009, 21:27
  4. Brake Bleeding
    By GSXpress in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2007, 11:56
  5. Brake Bleeding
    By Pat in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2007, 12:49
