Sky InsuranceVolks Autos
    May 2011
    11
    VCDS Adaption Error - 'Staging'
    Hey guys,
    I am using a genuine VCDS Ross-Tech cable and version 11.11.3 software and have a problem with an Adaption Error.
    I am trying to switch on 'Staging' aka Needle Sweep in the Instrument 17 Adaption channel.
    I am unable to activate and save 'Staging' and the following errors appear.
    'This appears to be an uninitialised control module;
    A valid WSC/Importer/Equipment data may be required.
    Click [yes] for VCDS to use default values of 12345/123/12345.
    Click [no] for VCDS to try the values currently in the module.
    Click [cancel] to go back and manually edit the values.'
    'This workshop identification:
    WSC 00046 Importer 790 Equipment 12345
    was rejected by the control module.
    The command will probably fail.
    Please change your values.'
    I did click [no] the first time i tried to change the 'Staging' which produced the error... I tried a second time clicking [yes] which did not work. I have re-installed the 11.11.3 software, but still no luck.
    Any ideas?
    Thanks.
    26,762
    On what car?
    May 2011
    11
    Problem sorted... Ross-Tech customer service is great! I needed to enter the 12345 code to access
    26,762
    Ok, but next time put your car info, as some things arent supported on every car.
  1. Power Loss issues (VCDS Error inside)
    By Nilz in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th March 2012, 12:38
  2. Audi DRLs now not working - VCDS coding error
    By vagcat in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th July 2011, 20:48
  3. Replies: 24
    Last Post: 10th October 2010, 17:40
  4. Cat Sensor Error Codes from VCDS....
    By jb0o in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2010, 08:44
  5. Error Code: 16985 - Internal Control Module: Memory Check Sum Error
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 11:34
