Results 1 to 12 of 12
    Feb 2012
    Banbury
    24
    Question RNS-E coding failure help
    Hi Guys and Gals!,
    Been on the site for a sort while now and found loads of useful comment on how to fix about everything, BUT this I can find!
    I an trying to code my RNS-e and it keeps coming up with error 31 message, what am I doing wrong?
    Help please, NHN has said that my RNS has been hacked as firmware has an "X" in it, is this the problem, if so, how do I get round this?
    this is my log:
    Many many thanks in advance... all this just to get the buttons on my MSFW to work, "Mode" button that is!!!
    Saturday,21,April,2012,15:25:12:36306
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 7D
    VIN: WAUZZZ8P56A170695 Mileage: 91370km/56774miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 FF HW: 028 101 190 5
    Component: R4 2,0L EDC G000SG 7364
    Revision: 12345678 Serial number: AUX7Z0F1FNM071
    Coding: 0000072
    Shop #: WSC 06314 000 00000
    VCID: 6CDCBF644F90D69
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 00205 210 90077
    VCID: 73EEA41812AE091
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
    Component: KlimavollautomatH18 0260
    Revision: 045099 Serial number: 8P0820043P
    VCID: 397256307042B31
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H43 1201
    Revision: 00H43000 Serial number: 00000005483055
    Coding: 01884F01B214100000160000160000000008FE175C0100
    Shop #: WSC 80093 222 69422
    VCID: 40843BD41398E29
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00055568
    Shop #: WSC 80093
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H12 3760
    Revision: 91H12376 Serial number: 00362006K464
    Coding: 0071612
    VCID: 428031DC1D94F09
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H37 0070
    Coding: 0002042
    Shop #: WSC 12345 123 12345
    VCID: 41823ED01892EB1
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0420
    Revision: D06 Serial number: 2241FD06013118
    Coding: 0004413
    VCID: 377650084656A51
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 3000106206822B
    Coding: 3D3F0B4207002103
    VCID: 2B5E7C788A1E111
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D06 Serial number: AUX7Z0F1FNM071
    Shop #: WSC 00000 000 00000
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
    Component: RNS-E HIGH EU H80 X---
    Revision: 20S Serial number: AUZBZ7K4100999
    Coding: 0205700
    VCID: 3F8638286E669D1
    2 Faults Found:
    01303 - Telephone Transceiver (R36)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 82
    Mileage: 91304 km
    Time Indication: 0
    Date: 2012.04.18
    Time: 18:45:11
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 82
    Mileage: 91304 km
    Time Indication: 0
    Date: 2012.04.18
    Time: 18:44:51
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000688
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 346C670457204E9
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    Coding: 198000186D088505489FC63300
    VCID: 3C7C4F247F70869
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH04 0180
    Revision: 00003 Serial number: 30674548462227
    VCID: F1E22E10E8B2BB1
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
    Part No: 8P0 959 802 H
    Coding: 0000688
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205700
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 82
    Mileage: 91304 km
    Time Indication: 0
    Date: 2012.04.18
    Time: 18:45:11
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 82
    Mileage: 91304 km
    Time Indication: 0
    Date: 2012.04.18
    Time: 18:44:51
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 D
    Component: Tuer-SG 020 0070
    Coding: 0000144
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 D
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D5A7260B40A1F1
    26,775
    What coding are you trying to use?
    Feb 2012
    Banbury
    24
    trying to change the channel 37 or 56 from 0205700 to 0205135
    just trying one digit at a time,
    tried 0205705 for mfsw, but keep getting error 31
    tried 0205100 for mfsw, but keep getting error 31
    Sep 2007
    North-East UK
    93
    Try 0205115 for the RNS-E. The Steering Wheel coding is correct.
    Steve
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    Feb 2012
    Banbury
    24
    Quote Originally Posted by JST_A3 View Post
    Steve
    Thanks for that, that worked. still have 2 faults on it tho, any thoughts?
    Coding: 0205115
    2 Faults Found:
    02454 - Microphone Unit (in Front Roof Module) (R164)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 103
    Mileage: 91716 km
    Time Indication: 0
    Date: 2012.04.28
    Time: 10:51:13
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 103
    Mileage: 91716 km
    Time Indication: 0
    Date: 2012.04.28
    Time: 10:51:08
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes, your mic fault is because the unit has been hacked for SDS and is looking for a voice control mic in the roof, two options, fit a mic and connect it to the RNS-E, or downgrade/upgrade the RNS-E to get rid of the SDS hack and then you don't need a mic and X--- will gio away as well.
    Second fault if not because you have missed an option such as BOSE or Ipod interface/CD then it is probably an adaptation issue, have you actually been through the channels to check the adaptations?
    Feb 2012
    Banbury
    24
    Quote Originally Posted by s8craig View Post
    Been through the adaptions many times, sure they are right... now!
    I do have an ipod connector, maybe that's whats throwing it off, will have to find that code then...
    If I put a mic in, will it work for the functions, so if I press the ptt button, or do I need something more?
    where do you get one of those mic's, I was planning a full bluetooth install, when I have some more pocket money, is that the mic I could use?
    Otherwise i'll upgrade or downgrade once I find out how to..
    Many thanks
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    CD changer/Ipod is easy, change 0205115 to 0205117
    As for the mic it will give you SDS for the navigation/Radio etc if you fit it and wire it into the RNS-E, further along the line it can be used for the bluetooth kit as well.
    Feb 2012
    Banbury
    24
    Worked spot on, thanks, When I either sort out a bluetooth kit or a mic, I will sort out the last bit!
    If anyone has any info on how to wire a mic in to do the SDS with out the bluetooth kit and what parts I need to do this, I'd appreciate it.
    Feb 2012
    Banbury
    24
    Got my bluetooth kit today, all installed and works, just two problems that I need to overcome now.
    The mic works, but the basis sds on the B/T kit doesn't.
    I want to set up the full SDS, any ideas out there?
    Dave
    Sep 2007
    North-East UK
    93
    Dave,
    Have you coded the Bluetooth module yet? There's a guide here that should help: Audi A3 (8P) Telephone Preparation - Ross-Tech Wiki
    Based on you current installation you could try a coding of 0011422, but please check the link as some adaptation may also be required.
    Steve
    MY2011 A1 TDI Sport
    Feb 2012
    Banbury
    24
    Dave,
    Steve
    Thanks Steve,
    I coded modules 16,19,37 and 77. their codes below. I'm just wonering if its because i'm going from and old stereo (concert) with iso conections, to the dlock, then to another dlock for the bluetooth, maybe missing some pins, will have to check tomorrow as well as the adaption in 77
    Coding: 0004042
    Coding: 3D3F0BCA07002103
    Coding: 0205715
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
    Component: FSE_256x BT H34 0600
    Revision: 00000000 Serial number: 00000005128341
    Coding: 0011422
    Shop #: WSC 00502 210 86012
    VCID: 75EA9A001CDA171
    Dave
  1. RNS-e Coding
    By Stuart Dobson in forum VCDS (formerly VAG-COM) forum
    Last Post: 25th October 2011, 09:43
  2. Coding RNS-E
    By BlackQuat in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th April 2010, 22:50
  3. RNS-E Disc failure
    By vadhert in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2010, 14:01
  4. rns e coding
    By vinceemmery in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st December 2007, 10:06
  5. Coding for RNS-E with B6 A4
    By Silverfox42badger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th January 2007, 14:05
