AH FabricationsBadger5
    Feb 2011
    15
    A3 2.0TFSi Fault Codes
    Got the following codes constantly now, ie reappear straight away after being cleared. Had them intermittently over last year.
    12600 P3138 Intake Manifold Flap Control
    08200 P2008 Intake Manifold Flap Motor Open Circuit
    Also now had
    12599 P3137 Basic Settings Not Carried Out
    01602 Electric Drive Motor (V141) Sporadic 002 - Lower Limit Exceeded
    but these have cleared down and not reappeared yet.
    The engine light has not illuminated on the dash at any stage though and the car runs fine. No erratic idle or problems when switching off as often reported for the first two codes.
    The first two codes are well documented and point to Intake Flap Motor V157 possibly needing replacing. I understand 12599 also relates to V157.
    Does anyone know what 'Electric Drive Motor V141' is though ?
    27,114
    Sort the IMF problem 1st then see whats left, I know on the derv they used to break inside on the plastic teeth, so remove & check functionality.
  1. Fault Codes
    By stevehall in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th August 2010, 22:13
  2. Fault codes
    By MPP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th June 2010, 17:53
  3. Fault codes
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2008, 17:32
  4. misfiring fault, tech help needed - have vagcom fault codes
    By shufti in forum General Technical / How To
    Last Post: 16th June 2006, 22:14
  5. Fault codes
    By owdgit in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th January 2006, 15:16
