Thread: VCDS and ABS
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,504
    VCDS and ABS
    Hi all,
    I've got the common 'ABS coming in at low speeds as i'm about to stop'
    VCDS hasn't picked up any DTC's as in no sensor failure.
    But is there a way VCDS can detect which sensor it is that is activating the ABS?
    Cheers,
    Dan
    2002 2.5 V6 Quattro
    Jan 2011
    Aberdeenshire
    628
    It will most likely be a cracked reluctor ring, or slightly misaligned sensor.
    Log all 4 wheelspeeds with VCDS, remembering it will kick out above 20(i think)km.
    Play the file back, and the duff wheel will show as spikes on the graph
    If it is the rear reluctor on a quattro, either repair it by welding and grinding/filing (I had two go and tried both methods sucessfully)or you can get one from ABSreluctors.com (I think that's the address) as they were quite hard to find. The front ones are for sale all over the place.
    1999 A4 B5 1.9 TDi FWD Saloon, Green
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine)
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    26,722
    Pretty good if they dont make one currently, they'll make one for free for you, to be able to create a mould etc
    ABS Reluctor Rings
    Jan 2011
    Aberdeenshire
    628
    That's the crowd I meant, Nigel!
    Not very cheap if they don't need yours though -£50ish for 1, although multiples were cheaper IIRC. Fast delivery and ok to deal with. Although Audi will only sell the CV joint with the ring fitted - much more than £50
    26,722
    Thats VAG for you, some parts I have supplied this time last year were iirc £260, now they're over £400, its obscene tbh, its not the dealers either, audi charge a ransom to dealers & I've seen some of there percentages, its awful.
  1. VCDS is it the same for VW as Audi ? or anyone in cumbria with VCDS
    By brough74 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2011, 12:47
  2. ABS module won't code with VCDS???
    By BILKO1 in forum VCDS (formerly VAG-COM) forum
    Last Post: 4th February 2011, 07:01
  3. ABS & Traction Control Light On... ABS Not Working
    By Gibonz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th August 2010, 09:32
  4. Anyone had an abs sensor fail and picked it up with VCDS ?
    By myke in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2010, 16:52
  5. ABS module on the abs pump
    By sun and kath in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th January 2010, 20:56
