Volks AutosEM Tuning
Results 1 to 1 of 1
    Mar 2012
    14
    Car not running quite right
    Good morning folks.
    I've got a leon cupra-180 and it has been running flat in 4/5/6 and doesnt pull amazingly in 1/2/3.
    I've replaced the recirc valve, it used to flutter and the spring was useless-now it is silent again but still runs a bit lame.
    I've switched back to 98 ron fuel but to be honest I can't see 95 making this much of a difference.
    Emissions some back perfect on mot ramp. Spark plugs seem ok, no obvious pipe leaks. I cleaned the throttle body and had that realigned also
    I had some data logs from vag com, was advised to replace the air flow meter which I did to prove no more positive. One thing that was noticed was how much advance was being pulled out-this was whilst being run on 95 i'll admit
    Can anyone take a look at my logs and see if there is anything that stands out?
    i've got them on an excel sheet as typing them up here would create the longest post in history. If you might be able to assist could you put your email up and I can send them through asap.
    Thanks in advance for any assistance
    Scotty
  1. Cant get a good quote for first car 20 year old
    By Gareth a3 in forum Insurance - Sponsored by Sky Insurance
    Last Post: 21st April 2012, 23:34
  2. Running New Car In
    By nicks3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2009, 16:28
  3. Running a new car in?
    By ferris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2009, 18:51
  4. First audi quote quote is it good/bad ?
    By grumpytraveller in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th November 2008, 07:23
  5. car seems to be running on 2 cyl while starting up when cold.
    By inetforce in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2007, 18:36
