EM TuningAH Fabrications
Results 1 to 7 of 7
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    '10 S3: Pano sunroof open/close via keyfob and S-tronic adaption
    As above is there any way to employ VCDS to set the sunroof to open or close from the key fob like you would the windows?
    Secondly, I regularly do the throttle body adaption, but is there something similar for the DSG/S-tronic boxes?
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    27,110
    Do you have a log of your car?
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Nothing with me at the moment unfortunately. Lent the cable to a mate last week and the bugger hasn't returned it...
    Ex: 1978 VW Beetle
    27,110
    When you get the log then post it up.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Close sunroof using key fob or auto close if it rains.
    Hi,
    I'd like to do the same thing on MY2009 Quattro.
    Hope you can help.
    Log below taken using a genuine VCDS Cable.
    One last thing. My Golf GTi MY2005, from memory had some option were the sunroof would auto close if it rained.
    Does this option/coding exist for MY 2009 A3 fitted with auto wipers.?
    Friday,16,March,2012,13:39:21:49592
    VCDS Version: Release 11.11.2
    Data version: 20120126
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 72
    VIN: WAUZZZ8P49A099221 Mileage: 64000km/39767miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
    Part No SW: 8P0 907 115 AE HW: 8P0 907 115 Q
    Component: 2.0l R4/4V TFSI 0020
    Revision: AAH03--- Serial number: AUX7Z0I0FN70YJ
    Coding: 0103000C1C0F0060
    Shop #: WSC 06314 000 00000
    VCID: 75EA7AE71CDA17B
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 011 DC HW: 02E 927 770 AJ
    Component: GSG DSG AG6 440 1905
    Revision: 04844002 Serial number: 00000811271320
    Coding: 0000020
    VCID: 53AEE47FF2EE69B
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
    Component: ESP MK60EC1 H35 0106
    Revision: 00H35001
    Coding: 16426012092B0003680D06E6901A0081B900
    VCID: 75EA7AE7DCDA17B
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
    Component: KlimavollautomatH09 0100
    Revision: 000066 Serial number: 8P0820043BG
    Shop #: WSC 00000 000 00000
    VCID: 72E041FB6DB4003
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
    Component: Bordnetz-SG H54 2801
    Revision: 00H54000 Serial number: 00000009275020
    Coding: F58E1F81B0141380EF00000A0000000000084E056406040364 2000000000
    Shop #: WSC 06314 000 08192
    VCID: 4894C3133BA8DA3
    Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00056595
    Shop #: WSC 06314
    Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH04 0003
    Coding: 00150573
    Shop #: WSC 06314
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X2.clb
    Part No SW: 8P0 919 475 D HW: 8P0 919 475 A
    Component: PARKHILFE 8K H06 0102
    Revision: 11001001 Serial number: 84640835203257
    Coding: 000105
    VCID: 3F86D8CFAE669DB
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
    Component: Airbag AU1042 H06 0090
    Revision: -------- Serial number: 003000000000
    Coding: 303142383038303030374A55305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 4992C617E8A223B
    Crash sensor for side airbag; driver side:
    Serial number: 3572DRB400008854B16T
    Crash sensor for side airbag; passenger side:
    Serial number: 3582DRB40000885521BR
    Crash sensor for side airbag; rear driver side:
    Serial number: 35128RB4000048DE27BY
    Crash sensor for side airbag; rear passenger side:
    Serial number: 35228RB4000048DFA6A%
    Crash sensor for front airbag; driver side:
    Serial number: 35547RB400004A3859AT
    Crash sensor for front airbag; passenger side:
    Serial number: 35647RB400004A385D8W
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0012112
    VCID: 4182DE371892EBB
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 982 E HW: 8P0 920 982 E
    Component: KOMBIINSTR. VDO H19 0860
    Revision: D0H19007 Serial number: 2240I007006020
    Coding: 0033428
    Shop #: WSC 00370 210 999999
    VCID: 3B7EACDF7A7E81B
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 S HW: 1K0 907 951
    Component: J533__Gateway H16 0210
    Revision: H16 Serial number: 3400K0911410C5
    Coding: EDA37F06000202002103
    VCID: 3776B0EF4656A5B
    Address 22: AWD Labels: Redir Fail!
    Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
    Component: Haldex 4Motion 3016
    Coding: 0000005
    VCID: 438ED43F028EF9B
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H19007 Serial number: AUX7Z0I0FN70YJ
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
    Component: Tuer-SG H03 0060
    Coding: 0000764
    VCID: 4280D13B1D94F03
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 E
    Component: EPS_ZFLS Kl. 233 2501
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2C5C9F838F10163
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1980200002186D0985054C9FC637
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
    Coding: 0000764
    Address 55: Xenon Range Labels: 4F0-910-357.lbl
    Part No SW: 4L0 910 357 HW: 4L0 907 357
    Component: AFS 1 H01 0040
    Revision: 00000001 Serial number:
    Coding: 0000028
    VCID: E9D2A697C06243B
    Part No: 7L6 941 329 B
    Component: AFS-Modul links H03 S004
    Component: AFS-Modul rechtsH03 S004
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
    Component: R Concert2+ H03 0270
    Revision: 00H03000 Serial number: AUZ1Z3I9716641
    Coding: 0330201
    VCID: 3F86D8CF6E669DB
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000216
    Shop #: WSC 06314 000 1012544
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000216
    27,110
    You would need to login to convenience module 46, code comfort closing for roof & see if does via the remote with windows & doors, it works on a normal roof, not tested with a pano yet.
    As for the rain sensor closure, on the older CE/Conv modules I dont think it did this, the newer which yours isnt, I think has the ability.
    Oct 2013
    London
    200
    Acheron, did you ever get this working?
    I've got a pan roof on my A3 and I'm looking to add this feature.
    A quick scan shows I've got a 8P0 959 433 C (I don't have the option to close roof, via VagCom).
    Would I be able to just fit a J unit in my car: ebay link? 2006 A3 sportback Pan Roof.
  1. boot to open fully of keyfob
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st January 2011, 19:27
  2. Still cannot open/close
    By jolly14 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th May 2010, 19:45
  3. Sunroof & convenience close on MY10 models
    By Lima in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th January 2010, 10:43
  4. Door open/close sensor?
    By SmoothAssault in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2008, 00:48
  5. Open sky and auto-close
    By Twizzler in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th November 2007, 17:13
