Hi,
I'd like to do the same thing on MY2009 Quattro.
Hope you can help.
Log below taken using a genuine VCDS Cable.
One last thing. My Golf GTi MY2005, from memory had some option were the sunroof would auto close if it rained.
Does this option/coding exist for MY 2009 A3 fitted with auto wipers.?
Friday,16,March,2012,13:39:21:49592
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 72
VIN: WAUZZZ8P49A099221 Mileage: 64000km/39767miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 8P0 907 115 AE HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0020
Revision: AAH03--- Serial number: AUX7Z0I0FN70YJ
Coding: 0103000C1C0F0060
Shop #: WSC 06314 000 00000
VCID: 75EA7AE71CDA17B
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 011 DC HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1905
Revision: 04844002 Serial number: 00000811271320
Coding: 0000020
VCID: 53AEE47FF2EE69B
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 16426012092B0003680D06E6901A0081B900
VCID: 75EA7AE7DCDA17B
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000066 Serial number: 8P0820043BG
Shop #: WSC 00000 000 00000
VCID: 72E041FB6DB4003
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009275020
Coding: F58E1F81B0141380EF00000A0000000000084E0564060403642000000000
Shop #: WSC 06314 000 08192
VCID: 4894C3133BA8DA3
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 06314
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 D HW: 8P0 919 475 A
Component: PARKHILFE 8K H06 0102
Revision: 11001001 Serial number: 84640835203257
Coding: 000105
VCID: 3F86D8CFAE669DB
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4992C617E8A223B
Crash sensor for side airbag; driver side:
Serial number: 3572DRB400008854B16T
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000885521BR
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB4000048DE27BY
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB4000048DFA6A%
Crash sensor for front airbag; driver side:
Serial number: 35547RB400004A3859AT
Crash sensor for front airbag; passenger side:
Serial number: 35647RB400004A385D8W
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0012112
VCID: 4182DE371892EBB
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 E HW: 8P0 920 982 E
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2240I007006020
Coding: 0033428
Shop #: WSC 00370 210 999999
VCID: 3B7EACDF7A7E81B
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0911410C5
Coding: EDA37F06000202002103
VCID: 3776B0EF4656A5B
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 438ED43F028EF9B
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H19007 Serial number: AUX7Z0I0FN70YJ
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0000764
VCID: 4280D13B1D94F03
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5C9F838F10163
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0000764
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Revision: 00000001 Serial number:
Coding: 0000028
VCID: E9D2A697C06243B
Part No: 7L6 941 329 B
Component: AFS-Modul links H03 S004
Component: AFS-Modul rechtsH03 S004
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3I9716641
Coding: 0330201
VCID: 3F86D8CF6E669DB
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000216
