My B7 that I just picked up doesn't warn me when the seatbelt is unplugged, strangely it doesn't warn me when the lights are left on accidentally... Are these two linked (central convenience?) or easily re-activated?
Check your seat belt clip by center console & see if it has the wire going up the side, if not then it wont have the chime anyway regardless of coding.
Do you have the coming/leaving home system fitted, check the headlight dial for the auto position, as this wont chime if its in that position.
