dme
Good afternoon all,
I love this forum, I have been reading for weeks. I have recently retrofitted RNS-E, AUDI BT Phone wired for SDS and MFSW. I have most of it working but have a few errors I would like to discuss with the knowledgeable, helpful folks on here. I have the BT phone volume problem that appears to be well documented; however I have a few errors I would like to get sorted first.
I have a 2006 A3 Sportsback 2.0 TDI DSG. I have a mate who has a genuine RT VCDS, here are the logs with errors. Any help would be massively appreciated.
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 77
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC G000AG 9558
Revision: --H06--- Serial number: AUX7Z0G0FN80RO
Coding: 0000078
Shop #: WSC 06314 000 00000
VCID: 6FE9D78F070D
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 M HW: 02E 927 770 AE
Component: GSG DSG 070 1301
Revision: 00007000 Serial number: 00000612091104
Coding: 0000020
VCID: 1E37DA4BB027
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
VCID: 73E1DBFF6B25
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
Component: KlimavollautomatH19 0360
Revision: 087601 Serial number: 8P0820043AC
VCID: 6DD5CD870D01
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006533180
Coding: E4885F21B014100000160000160000000008FA175C0100
Shop #: WSC 06314 000 08192
VCID: 408B44336A13
Part No: 8P2 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
00526 - Brake Light Switch-F
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 105298 km
Time Indication: 0
Date: 2012.02.24
Time: 15:21:00
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
ON
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H13 4260
Revision: 91H13426 Serial number: 003620G3CS4V
Coding: 0071612
VCID: 428F4E3B641F
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0013142
VCID: 418D41376119
Part No: XXXXXXXXXXX
Component: E0221 H02 0100
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2240G004009912
Coding: 0002413
Shop #: WSC 00646 210 99117
VCID: 3B7133DF03F5
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106C110655
Coding: 3F3F03CA07002103
Shop #: WSC 06314 123 12345
VCID: 2F69178FC78D
1 Fault Found:
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 13
Reset counter: 246
Mileage: 104040 km
Time Indication: 0
Date: 2012.01.27
Time: 00:09:37
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20004 Serial number: AUX7Z0G0FN80RO
Shop #: WSC 00000 000 00000
VCID: 3B7133DF03F5
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 192 S HW: 8P0 035 192 S
Component: RNS-E HIGH EU H80 X---
Revision: 20S Serial number: AUZBZ7K4100844
Coding: 0205717
Shop #: WSC 06314 211 03176
VCID: 3F8947CF17ED
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 84
Freeze Frame:
Voltage: 11.80 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 246
Mileage: 104040 km
Time Indication: 0
Date: 2012.01.27
Time: 00:08:01
Freeze Frame:
Mileage: 104040 km
Count: 2701
Clock: 00:07
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 104217 km
Time Indication: 0
Date: 2012.01.31
Time: 12:08:23
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000760
VCID: 408B44336A13
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 356525E725D1
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H08 0070
Coding: 9980202002186D098505489FC637
VCID: 3F8947CF17ED
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674697024710
VCID: F1ED51F79139
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000760
VCID: 418D41376119
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205717
VCID: 3F8947CF17ED
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 84
Freeze Frame:
Voltage: 11.80 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 246
Mileage: 104040 km
Time Indication: 0
Date: 2012.01.27
Time: 00:08:01
Freeze Frame:
Mileage: 104040 km
Count: 2701
Clock: 00:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 104217 km
Time Indication: 0
Date: 2012.01.31
Time: 12:08:23
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000216
VCID: 408B44336A13
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000216
VCID: 418D41376119
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005101636
Coding: 0011402
Shop #: WSC 06314 211 00000
VCID: 3B7133DF03F5
Many thanks,
DME
Chassis Type: 1K0
Coding: 0000078
VCID: 6FE9D78F070D
Coding: 0000020
VCID: 1E37DA4BB027
Revision: 00H11001
Coding: 0023170
VCID: 73E1DBFF6B25
VCID: 6DD5CD870D01
VCID: 408B44336A13
Coding: 00062736
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 105298 km
Time Indication: 0
Date: 2012.02.24
Time: 15:21:00
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
ON
Coding: 0071612
VCID: 428F4E3B641F
Coding: 0013142
VCID: 418D41376119
1 Fault Found:
014 - Defective
Coding: 0002413
VCID: 3B7133DF03F5
VCID: 2F69178FC78D
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 246
Mileage: 104040 km
Time Indication: 0
Date: 2012.01.27
Time: 00:09:37
VCID: 3B7133DF03F5
Coding: 0205717
VCID: 3F8947CF17ED
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 84
Freeze Frame:
Voltage: 11.80 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 246
Mileage: 104040 km
Time Indication: 0
Date: 2012.01.27
Time: 00:08:01
Freeze Frame:
Mileage: 104040 km
Count: 2701
Clock: 00:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 104217 km
Time Indication: 0
Date: 2012.01.31
Time: 12:08:23
Coding: 0000760
VCID: 408B44336A13
VCID: 356525E725D1
VCID: 3F8947CF17ED
VCID: F1ED51F79139
Coding: 0000760
VCID: 418D41376119
Coding: 0205717
VCID: 3F8947CF17ED
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 84
Freeze Frame:
Voltage: 11.80 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 246
Mileage: 104040 km
Time Indication: 0
Date: 2012.01.27
Time: 00:08:01
Freeze Frame:
Mileage: 104040 km
Count: 2701
Clock: 00:07
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 104217 km
Time Indication: 0
Date: 2012.01.31
Time: 12:08:23
Coding: 0000216
VCID: 408B44336A13
Coding: 0000216
VCID: 418D41376119
Coding: 0011402
VCID: 3B7133DF03F5
Many thanks,
DME
