EM TuningAH Fabrications
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    9,640
    Polo 6n2 cutting out with error codes
    Did a scan on the wifes polo earlier as she said that it keeps cutting out intermittently, the below faults came up on it. This has been going on for a while now and I have already replaced the camshaft sensor and its still the same, someone else mentioned it could be the crank sensor (?)
    Can anyone advise at all on the below please?
    3 Faults Found:
    00519 - Intake Manifold Pressure Sensor (G71)
    31-10 - Open or Short to Ground - Intermittent
    00513 - Shareware Version. To Decode all DTCs
    03-10 - Please Register/Activate - Intermittent
    00282 - Shareware Version. To Decode all DTCs
    26-10 - Please Register/Activate - Intermittent
    Thanks in advance
    Nilz
    Jan 2011
    northants
    165
    first clean out throttle body and reset
    remove map sensor and clean first but you may need to replace
    also check cam timing if 16v engine as this fault can come up if timing slipped
  1. Polo cutting out
    By Scott_Hol in forum Volkswagen and other VAG
    Last Post: 13th February 2012, 19:16
  2. VW Polo cutting out
    By Scott_Hol in forum General Automotive Chat
    Last Post: 10th February 2012, 09:30
  3. VW Polo Fault codes
    By simfin in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th February 2011, 22:21
  4. Some error codes
    By 0w3n in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2008, 20:04
