EM TuningAMD Technik
Results 1 to 13 of 13
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    Can someone log a block in a MY2007 A3 8P or later.
    Trying to confirm something that I have read regarding a G89 sensor.
    I'm after the reading in the second channel.
    I have attached a photo for reference.
    Module 08 HVAC
    Measuring block : 010
    Thanks.
    18,288
    Post Thanks / Like
    What exactly are you trying to confirm?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Jan 2012
    48
    Post Thanks / Like
    At a guess I would think he's wondering why the Fresh Air Itake (G89) is reading -50 Deg C. Looks a bit cold to me, possibly the sensor has failed?
    Take this as a stab in the dark though as I have absolutely no experience with VCDS.
    18,288
    Post Thanks / Like
    lmfao, oops didnt see the minus, my excuse, got home at 11pm from work & promptly passed out non alcohol induced :P
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    Yep the -50 degrees seems to suggest that something is wrong.
    Elsawin suggests that the G89 sensor was being fazed out from 2006 and the reading is nothing to be worried about.
    Just need to see another cars reading for this block.
    We also can't find the sensor anywhere or it's in the actual aircon unit which involves a dash out, aircon out job just to replace a £20 sensor.
    18,288
    Post Thanks / Like
    But do you actually have an issue that you've found or you were just browsing with vcds & found that & wondered why?
    Yes there were a few changes in mid 07 on the climate side which is why the new chrome style units can be used on the older mid 07/08 cars.
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    The car had the econ light on permanently. There was no refrigerant or pressure in the system.
    It was re-gassed and HVAC was checked on VCDS by my mechanic.
    We sought to replace the G89 sensor and failed to find its location
    I'm still researching at the moment if this is an actual issue, a red herring or even if this sensor actually exists.
    18,288
    Post Thanks / Like
    If you check the 20 pin red connector on climate unit, pin 10, see if this has a wire in, if not, then yours would appear to be the newer type that removed the G89 sensor, if the wires present, then you need to find the sensor.
    G89 - Fresh air intake duct temperature sensor
    It shows approx 4 of these sensor types, all plummed into the ducting & they look accessible.
  10. Thanks tbcuprat thanked for this post
  11. #9
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    Hi Nigel,
    I will attempt to remove the climatronic and check the pinout.
    I have found four sensors. Only the two outer vents share the same part number as the suspect G89.
    Thanks for your help.
  12. #10
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    Your advice was tip top Nigel.
    Pin 10 is empty. So a definitely no G89 sensor and not a reading to be concerned about.
    Just curious what other A3's with climatronic and of similar age say when reading this channel on VCDS.
  13. #11
    18,288
    Post Thanks / Like
    You may consider upgrading climate to the newer chrome version then
  14. #12
    tbcuprat's Avatar
    May 2006
    Basingstoke
    44
    Post Thanks / Like
    I think they may already be installed. Well the rings around the temperature selection is brushed metal. Are there different types?
  15. #13
    18,288
    Post Thanks / Like
  1. MY2007 Coin Tray to Cup Holder - Help
    By tbcuprat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th November 2011, 08:56
  2. Had a log done does it look ok.
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2011, 20:32
  3. my first log
    By Bradderz_1988 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th August 2011, 15:46
  4. First log on block 002
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2011, 19:45
  5. log on?
    By stewarta13wsb in forum Jokes, Games & Humour
    Last Post: 16th August 2006, 11:10
