Forge MotorsportKowalski
    Sep 2011
    Sunny Bangor. N.Wales.
    206
    Post Thanks / Like
    Code needed for egr shutoff on A4 2.5Tdi Quatt
    hi all as above, i have an audi "X"Reg A4 2.5 Tdi Quattro, basically i'm going to see a mate tomoz in manchester who has a full Vag-
    Com, but we're not sure how to shut the EGR off, any help and codes appriceated.
    Many Thanks
    Wayne.
    2000, A4 2.5Tdi Quattro.
    Tinted, 3600WATTSLoud
    Oct 2003
    up north...
    767
    Post Thanks / Like
    im pretty sure this isnt a vcds thing - its coded within the ecu programming and needs a remap to remove the function, along with a physical blanking plate - thats certainly the case with later PD cars that ive had
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Jan 2011
    Aberdeenshire
    213
    Post Thanks / Like
    On the Ross-Tech site (TDI VCDS Info) there is a coding value to change the valve duty cycle, effectively turning off the EGR. The value given doesn't work for the 2.5 V6 TDi, but go for the highest value possible.
    The login code for the AFB engine is 26242, not the value in their example.
    See Engine Adaptions Login for my inputs
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
  1. EGR blanking plate size 2.5tdi
    By nanafagis in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2011, 11:25
  2. 2.5Tdi EGR Problem?
    By herisites in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th July 2011, 20:23
  3. 2.5tdi engines code
    By willieigs in forum Diesel forum
    Last Post: 19th April 2011, 01:22
  4. 2.5Tdi dash swap skc code needed!
    By cheezeberger in forum A6/S6/Allroad forum (C5 & C6 Chassis)
    Last Post: 14th January 2009, 14:46
  5. EGR vavle needed?
    By meak80 in forum Diesel forum
    Last Post: 28th May 2007, 15:22
