DTUKGNJ
    Jun 2009
    145
    Post Thanks / Like
    Help - Battery drain (ongoing saga)
    Hi Guys,
    Hoping someone can help me with a persistant battery drain, more info....
    Radio causing battery drain? 00858
    Basically, batterys got a drain, no fault codes at present, was getting intermittent at convenience module till I repaired some wires in the door jamb. Hazard stays on solid all the time, all other electrics seem to be working fine, so is the alarm (as far as I can tell). Dash and interior door signals also all okay. Tried 2 new batteries, alternator is also fine, no blown fuses in dash. Once I Vagcom and clear a few modules (no codes but I clear anyway) the hazard goes off and drain goes away until I next drive the car. So im thinking something in the CAN system.
    Scanning now produces no codes, however, going into measuring blocks I get 2 different readings from the rear doors (these have winders). Front doors both go to locked and safe when I push the remote button. Really hoping someone can help as have tried pretty much everything and am losing hope.
    Thanks in advance
    Feb 2012
    Redruth
    6
    Post Thanks / Like
    Have you put a clamp amp meter on the + cable from the battery and checked the drain? The drain caused by the alarm and immobliser should be in the region of 300-500ma at most. How quick does the battery go flat?
    VCDS HEX+USB+CAN Full Version
    Pro-Scan
    Engine Check Pro
    DTUK/DTE Tuning & Pedal Boxes
  1. 1.8T AVJ battery drain
    By Alan H in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th May 2011, 08:51
  2. battery drain on tt
    By ty160 in forum TT/TT-S/TT-RS Forum
    Last Post: 12th September 2010, 18:56
  3. Please help (strange battery drain)
    By mrlinderley in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th March 2009, 20:12
  4. A4 Battery drain-help
    By audimike in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd December 2008, 07:24
  5. coupe battery drain
    By andy64 in forum Classic Audi Forum
    Last Post: 13th February 2006, 12:43
