JMB RetrofitsBadger5
    Aug 2011
    47
    bkd injector duty should reullts be so different between cylinders
    just tested my injector duty and there are not alll quite the same,results were
    cyl1 cyl2 cyl3 cyl4 measured in mg/str
    2.99 -3.01 -0.19 0.14 as it the car got warmer they went to
    2.82 1.6 -0.73 -0.45
    EDIT
    WHEN IT GOT UPTO FULL TEMP
    CYL 1 CYL 2 CYL 3 CYL 4
    1.71 -0.74 0.72 0.42
    should there be such a big difference between the cylinders
    cheers in advance for your help
    Aug 2011
    47
    ok looking on google iv got that cylinder 1 is maxed out and cyl 2 could be low cos its trying to compensate,just need to figure out what would cause that,google searching i have figured
    worn cam
    low compression
    faulty injector loom
    pourus head
    any one else know of anything that might cause this
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,525
    Looks like the age old injector failure. IIRC there is some kind of action where Audi replace the faulty units with new improved ones
    Aug 2011
    47
    the strange thing is though i have already replace the injector in cyl 1 and the mechanic said when he took them out that the injectors had already been done before that cos they were exchange units.
  1. running on 3 cylinders/ misfire. help needed :(
    By xCoupexAshx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2011, 20:03
  2. Missfire on all cylinders and smoke :(
    By markthenewt in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2011, 21:38
  3. 6 Cylinders?
    By Jackal in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2011, 21:35
  4. Audi A8 3.7, missing ! Not running on all cylinders
    By ian-gts in forum A8/S8 forum
    Last Post: 1st December 2009, 19:07
  5. The sound of 5 cylinders
    By K7ERG in forum You Tube Links
    Last Post: 5th July 2008, 21:22
