UnicornDTUK
    Aug 2011
    46
    Post Thanks / Like
    first Time user checking torsion value
    ok just used my ross tech cable for the first time today,my car has an overfueling issue when its cold that im trying to find the cause,
    checking my torsion value first. and when i first start the car its at about 11 then drops down to 2.5 is that normal or should it start lower
    below is a link to a log i took
    LOG-01-004-xxx-xxx.CSV - File Shared from Box.net - Free Online File Storage
    only error code i had was
    16685 - Cylinder 1: Misfire Detected
    P0301 - 000 - -
    Freeze Frame:
    RPM: 819 /min
    Torque: 100.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.21 V
    Inj. Quantity: 2.96 mg/str
    Temperature: 13.5°C
    (no units): 0.0
    Jan 2012
    Hertford, UK
    97
    Post Thanks / Like
    Hi,
    Did you manage to correct your torsion value?
    I have a bit of a judder at certain revs and have just found out (thanks to the help of a fellow ASN member's VCDS) that my torsion value is 3.9 (advanced).
    So, I'm going to have to do fine tune the camshaft timing as described here:
    How to adjust rough idle and camshaft timing on VW and Audi TDI pumpe duse engine
    I'm interested to know if you went through the same thing and if you have any advice?
    Thanks!
  1. 2005 A3 2.0 TDI BKD - Torsion Timing Value!!!
    By darthmal in forum VCDS (formerly VAG-COM) forum
    Last Post: 8th October 2011, 01:11
  2. Replies: 15
    Last Post: 16th May 2011, 18:22
  3. Hi Folks - 1st Time Owner Long Time Admirer
    By Gavin G in forum The Welcome Section
    Last Post: 24th January 2011, 11:00
  4. JUST CHECKING!!
    By AUDI TURBO in forum Jokes, Games & Humour
    Last Post: 5th January 2008, 21:33
  5. A6 torsion or vibration problems
    By DejaDeja in forum General Technical / How To
    Last Post: 26th January 2005, 08:01
