Revo TechnikUnicorn
    Nov 2011
    16
    Post Thanks / Like
    1st scan of possible new car
    hi there I am new to the site and I currently have a A4 avant 04 1.9tdi.
    I am thinking of buying it from my mate and he has given me use of it for a few days.I scanned the car for codes and it showed quite a few.Could someone please tell me if they will be expensive and worth sorting or should I just walk away from the car..
    below is my scan of the car..
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: Mileage: 152810km/94951miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 LJ
    Component: 1,9l R4 EDC G000SG 5781
    Coding: 00002
    Shop #: WSC 63251
    WAUZZZ8E44A172529 AUZ6Z0C0428427
    1 Fault Found:
    17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
    P1586 - 35-10 - - - Intermittent
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 3429
    Coding: 04255
    Shop #: WSC 06435
    No fault code found.
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AA
    Component: A4 Klimaautomat 1323
    Coding: 00000
    Shop #: WSC 63251
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 00001
    Shop #: WSC 63251
    1 Fault Found:
    01502 - Bulb for Rear Fog; Left (L46)
    57-00 - Electric Circuit Failure
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63251 000 00000
    2 Faults Found:
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    012 - Electrical Fault in Circuit - Intermittent
    011 - Open Circuit - Intermittent
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 00042
    Shop #: WSC 63251
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00401
    Shop #: WSC 00847
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0704
    Coding: 00001
    Shop #: WSC 00000
    2 Faults Found:
    01463 - Alarm triggered by Sensor for anti-theft alarm System
    43-00 - Closed
    01462 - Anti-theft alarm ultra sonic Sensor (G209)
    53-10 - Supply Voltage Too Low - Intermittent
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BC
    Component: Komfortgerát T3B 1412
    Coding: 07115
    Shop #: WSC 63251
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 0003
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 0003
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0004
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0004
    6 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01572 - Alarm triggered by Door Contact Switch; Passenger Side
    35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Right Rear
    35-00 - -
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 L
    Component: concert II GRO 0001
    Coding: 01001
    Shop #: WSC 63251
    many thanks Moggie
    bez101's Avatar
    Jul 2008
    3,425
    Post Thanks / Like
    not to bad
    clear them run it around and rescan see what comes back
  1. Car Judder accelerating from 1st to 2nd gear
    By Spidey99 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th October 2011, 09:50
  2. New Car, 1st Audi
    By MurdochA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2011, 07:21
  3. My scan results S3 8L
    By rhubarb4 in forum VCDS (formerly VAG-COM) forum
    Last Post: 28th April 2011, 13:07
  4. VCDS scan - where?
    By Simon S4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th February 2011, 20:25
  5. Scan car, Gosport/Portsmouth area
    By polar in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th August 2010, 19:22
