Wednesday,26,October,2011,20:24:44:33950VCDS Version: Release 10.6.5
Data version: 20110930
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ11002328
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 FC
Component: 1.8L R4/5VT 0002
Coding: 11500
Shop #: WSC 01236
VCID: 64C9AF54DEC0
WAUZZZ8LZ11002328 AUZ7Z0A1800155
3 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0019970
Shop #: WSC 01236 785 00200
VCID: 2C590774F690
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 J
Component: A3 KLIMAAUTOMAT 0105
Coding: 00041
Shop #: WSC 01236
VCID: 2F631078C786
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 5008
Coding: 01104
Shop #: WSC 01236
VCID: 458F52D0753A
1 Fault Found:
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
32-10 - Resistance too High - Intermittent
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 E
Component: AB-KOMBIINSTR. VDO D12
Coding: 00444
Shop #: WSC 00618
VCID: 356F221025DA
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 01236
VCID: 2F631078C786
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0C123444AD8
1 Fault Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
