Is any one in the devon area with Vag Commander?
Or even bristol at a stretch.
Why Vag commander?
TT-RS 410hp revo
Fiat 500 1.3 tdi 120hp
A3 8P 2.0tdi 240hp Autograph Cars
RS4 B5 520hp MTM
S3 8L 345hp MTM
Volvo 850 T5 300hp BSR
Fiat Punto GT 130hp
Lancia Delta Turbo 185hp
Lancia Beta Coupe 122hp
Mini 74hp
I'm fitting a new clock to my car and I need to program my keys or the clock. I need the SKC code. I think, I'm still learning about this
This is what i'm doing and why I need it.
A small project
for a b5 car, one of the clone ebay versions will probably do what you want - its worth a punt for a few quid
TT-RS 410hp revo
RS4 B5 520hp MTM
S3 8L 345hp MTM
Fiat Punto GT 130hp
Mini 74hp
I got a copy of VAG Tacho 3.03 or what ever it is and it could not read the code from the new clocks.
VCDS works with the new clocks and Vag tacho works with the old clocks.
Just not the new one.
My original Pre-facelift clocks has just died and need sending away for repair so i'm hoping to get the facelift clocks fitted and working before they get sent away, so this has been stepped up a bit in importance.
Is anyone in the Devon, Cornwall or Somerset area that think they will be able to program my facelift clocks for my pre-facelift car?
Mainly programming a new key to the new cluster, I think the rest should work fine.
Vag tacho is a different product to Vag commander. Not much experience of it but it doesn't seem to work With many cars and commander would be better to get six and immo codes
TT-RS 410hp revo
RS4 B5 520hp MTM
S3 8L 345hp MTM
Fiat Punto GT 130hp
Mini 74hp
Vag Tacho seems a bit hit and miss with the newer ones.
Having to keep trying till it lets you in.
I don't have Vag commander and with my pre-facelift clocks broken, I'm a little under pressure to get this done.
Found a local guy whos willing to try and pull the SKC codes from my clocks for me. so hopefully he will be successful and I get it programmed then.
sounds better to let someone who already has the tools have a go than waste money and time on tools that may still not work
TT-RS 410hp revo
RS4 B5 520hp MTM
S3 8L 345hp MTM
Fiat Punto GT 130hp
Mini 74hp
